Grinding gears
Old Sep 27, 2017 | 12:35 AM
ZERRY 316's Avatar
ZERRY 316
Default Grinding gears
My 99 grinds gears when I shift into 4th over 3000RPM. I replaced gear oil (trans and diff) and motor mounts. Anything else I should try before a trans overhaul?
Old Sep 27, 2017 | 02:19 AM
WMark's Avatar
WMark
St. Jude Donor '11
I may be missing something, but aren't you on the wrong forum to ask this question? This is C7. Having said that, had a 2002 C5 manual, and after 55k miles, never had a grinding gear problem.
Old Sep 27, 2017 | 02:33 AM
djnice's Avatar
djnice
Sounds like synchros. Actually, I have the same issue on my 99 camaro. Interested to see what others say.
To Grinding gears
