crank no start with pcm0336
I have a 2001 base Corvette. I am experiencing a no start condition. It cranks but does not start. This had happened a few years ago and I removed the ignition module and cleaned the contacts and that fixed it. car started fine for 3 years. I started doing it again so I replaced the ignition module. cCar started but would quit and throw a code C1278. So I replaced the TCS. Car would start and I could drive it about a block and It would quit. I would wait about 15 min and it would start and run for a short time and quit. I got it back into the garage and now it won't start at all. does crank fine. Now it is throwing a pcm0336. i have run out of ideas
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Change that, clear ALL the DTCs and see where you're at and report back..
Bill
Moderator, Tech Contributor
Received 2,124 Likes
Received 19,303 Likes
'20-'21-'22-'23-'24
Closing the thread and moving it to C5 Tech.
