Snow tires what sizes?
Old Sep 30, 2017 | 01:00 PM
3musky3's Avatar
3musky3
Default Snow tires what sizes?
Curious as to what size will fit would like to run a little narrower and taller.
I have a few sets of wheels so could run 17's all around or even c6 18" front for the rear. Anybody out there changed up from stock sizes? Thanks in advance
Old Sep 30, 2017 | 03:49 PM
knewblewkorvette's Avatar
knewblewkorvette
snow
I'd contact Tire Rack and ask them but I'd guess they'd recommend stock sizes.
888-353-5082
Old Sep 30, 2017 | 04:34 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
We lived in Labrador (northeastern Canada) and northern Arizona where we averaged 9 feet of snow a year and the recommendation was always narrower and if possible, a little shorter. Within reason, a more narrow tire will cut through the snow better and with the smaller contact patch, you are effectively putting more psi on the tires. I'd also recommend using a second set of wheels so you are not constantly keeping the ice sludge (as well as whatever they are using to treat the roads), on your good wheels.
I second knewblewkorvette's suggestion to call Tire Rack, Discount Tire or any other good tire shop around you and get their recommendations.
Good Luck!!
Old Sep 30, 2017 | 11:22 PM
JR-01's Avatar
JR-01
Might want to put some airbags on it to get it up in the air. With 6 inches of snow on the road you would be plowing it with the air dam. Eventually it would fill up with snow and die.
Old Oct 1, 2017 | 01:06 AM
3musky3's Avatar
3musky3
Looking at 225/55/17 up front and 245/50/18 out back. Both these sizes are right at an inch taller(to help with plowing) and a little narrower. Not planning on driving with more than a few inches on ground have a 4wd for deep stuff it's just that winter was to long to be without the vet. Put it away on turkey day and was first week of May before was able to get it out of hibernation.
Love tirerack website unfortunately corvettes and snow don't show any matches or alternate sizes for C5's
Old Oct 1, 2017 | 08:56 AM
colderbythelake's Avatar
colderbythelake
Old Oct 1, 2017 | 10:11 AM
JR-01's Avatar
JR-01
Don't expect your car to last as long exposed to road chemicals. Brake and fuel lines, electrical connections, electronics, anything steel and rubber components get attacked by road chemicals.
Old Oct 1, 2017 | 10:33 AM
3musky3's Avatar
3musky3
With 230k miles on it I have had a lot of fun already so time to have some more
Old Oct 1, 2017 | 10:38 AM
3musky3's Avatar
3musky3
Originally Posted by colderbythelake
Wouldn't want to driving through your downtown with those hills
Well maybe with chains lol
Old Oct 1, 2017 | 10:58 AM
JR-01's Avatar
JR-01
OK. I get it. It is nearing the end of it's life so go for it. Nothin to lose.
Old Oct 1, 2017 | 03:50 PM
Route99's Avatar
Route99
What you are looking for is a little unusual, although your rationale is understandable. Think you would have to call them and have someone help you over the phone. I've also found Discount Tire to be very responsive and helpful. Good luck.
Old Oct 2, 2017 | 10:07 AM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
I have seen people running winter tires on C5's in thesee sizes with good results:
225/50-17 front
2554518 rear
jjc508520's Avatar
jjc508520
That happened to me when I ran my old '95 Z28 with Blizzaks in the snow - the radiator got plugged up with snow and I nearly overheated on a freezing night!
Old Nov 11, 2017 | 12:06 PM
3musky3's Avatar
3musky3
Default First drive in snow
About 3" on ground then couple more fell.
Went with 225/55/17 front and 245/50/18 back. Xice 3 get a slight rub on full lock turn to right only
Old Nov 11, 2017 | 12:36 PM
ZigZag's Avatar
ZigZag
Sacrilege !! !,000 our fathers and 2,000 hail mary's.
Old Nov 11, 2017 | 12:41 PM
3musky3's Avatar
3musky3
lol I'll get right on that. Now if I can just figure out how to mount a plow on
Old Nov 12, 2017 | 11:49 PM
JHrinsin's Avatar
JHrinsin
Just thinking out loud here, but for the price of those Michelin snow tires and the second set of rims, you may have been able to buy a cheap old winter beater 4wd pickup truck. When I was growing up, we called them "wood haulers", good for one (or possibly two seasons) and then dump them in the spring.
To Snow tires what sizes?
Old Nov 13, 2017 | 02:18 AM
striper's Avatar
striper
I had exactly the same thought when I read this thread. Even a cheap Rabbit with 4 snows would be a better choice.
Old Nov 13, 2017 | 02:50 AM
Shaolin Crane's Avatar
Shaolin Crane
Definitely 37x12.5-18
Old Nov 13, 2017 | 08:58 AM
In post 5, he states he already has a 4WD and would use it for deep snow.
Good luck driving the Vette around when the weather turns bad - hope the snow tires work well for you.
