Shudder while ideling
Old Oct 1, 2017 | 10:08 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Originally Posted by Allieboy
you always say the worst scenario? lol
If the car was mine it would be figured out within the hour compared to cheap (no possible way) guesses from the gallery.
Ignition misfire or valve spring.
Old Oct 1, 2017 | 10:33 PM
pghjeeper's Avatar
pghjeeper
Well unfortunalty it's mine and I'm not quite as awesome as you are. I'm trying to diagnose the problem the best way I can.
Old Oct 1, 2017 | 11:08 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Are you around Atlanta? I'd help.
The fact it happens (symptoms) especially low load/rpm dictates the potential causes mentioned. Most likely ignition but higher rpm pressure can control a valve more against the seat compared to a spring at low rpm letting it bounce.
Old Oct 1, 2017 | 11:27 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The same way a weak ignition at low rpm (mainly the wire or plug) is reminded by higher rpm. Doubtful it's an igintion coil based on symptoms, those break up under load which isn't the case here.
If I had to bet, I'd vote ignition wire, then spark plug (not really) then valve spring, then coil.
Let us know what I was.
Old Oct 1, 2017 | 11:34 PM
pghjeeper's Avatar
pghjeeper
Thanks sorry if I seemed a little pissy but I'm frustrated as this just happened out of the blue. I'll try the wires and plugs then if that doesn't work I guess I'll take it to the stealership and see that they say. Im all the way in Pittsburgh, Pa and unfortunalty we don't have any really great Corvette garages
Old Oct 2, 2017 | 12:43 PM
joezr2's Avatar
joezr2
Just in case you ever need the info- there is a Corvette specialty shop here in Erie: Harborvette. I don't know anything about them except that they have been around for quite a long time.
EDIT: found their website http://harborvette.com/
Old Oct 2, 2017 | 01:44 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you said you had fuel injection cleaner in it correct? maybe its working and loosening up crude....i would drive all of that out of the system before anything else.
Old Oct 2, 2017 | 02:05 PM
JR-01's Avatar
JR-01
He asked for other reasons his car could be idling rough. There are a lot of them besides ignition misfire or valve springs. Been there.
Old Oct 2, 2017 | 04:26 PM
pghjeeper's Avatar
pghjeeper
Didn't get to the plugs and wires today, I'll get to them tomorrow and update the thread accordingly.
Thanks for all the replies I'm a novice with computer controlled cars. If push came to shove would taking it to the stealer and letting them hook it up to their diagnostic machinery be able to pin point it easier?
Old Oct 3, 2017 | 06:14 PM
pghjeeper's Avatar
pghjeeper
So driving it over my buddies house to change the plugs and wires and CEL finally came on. Code came up p0300 multiple cylinder misfires. The misfire is now noticble across all rpm ranges.
So waiting for it to cool and gonna swap the plugs and wires
Old Oct 3, 2017 | 10:25 PM
pghjeeper's Avatar
pghjeeper
So we got it alll done the spark plug wires were completely dry rotted and pulled apart in my hands. The number 5 was by far the worst. The spark plug were mismatched it had 3 AC Delco and 5 Denso's. Once we swapped the plugs and wires it fired right up, CEL cleared and it was purring like a kitten.
Thabks for all the help gents
Old Oct 3, 2017 | 10:26 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
Mine shown those exact symptoms, as well as the random misfire code.. like I mentioned earlier, new plugs & a new IAT sensor fixed it right up.. so hopefully plugs and wires will solve your problems
Just saw your most recent post after I posted.. glad ya got her fixed up.. I figured that would do it
Old Oct 3, 2017 | 10:52 PM
  #33
~Josh's Avatar
~Josh
Banned Scam/Spammer
Glad you're rolling smooth.
