Oil pan bolt
Old Oct 3, 2017 | 06:56 AM
mfi's Avatar
mfi
Default Oil pan bolt
Had the oil changed yesterday. When it was up on the lift we noticed the bolt for the drain was pretty scraped. Guess it bottomed out pretty hard. It just missed mashing it which would have been a bit catastrophic. And the car isn't lowered at all. Something to check once in a while.
Old Oct 3, 2017 | 09:26 AM
Velocity_Vette's Avatar
Velocity_Vette
Although the pan for the LS1 in the C5 is fairly shallow due to the sump it still sits above the bottom cradle line at it's forward most point, so I'd assume any bottoming out would probably hit that first. I'd even go further and think the stock exhaust has potential to scrape due to how low it sits following the collector (it "hangs" below the car).
Do you do your own oil changes? If not, are you sure the bolt wasn't improperly removed? The last time I changed my oil my oil drain bolt was in very good condition and that's with a considerable amount of mileage (for a C5 at least). Cleaned the threads, and on it went. I also never use a 12 point socket on oil pan bolts due to their torque; always a six point.
Old Oct 3, 2017 | 12:22 PM
mfi's Avatar
mfi
it was a scrape for sure.
Old Oct 3, 2017 | 01:09 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
It sounds more like it could have really drug over a speed bump rather than bottoming out during normal driving. Thanks for the heads up on this.
Old Oct 3, 2017 | 03:19 PM
twokbolt's Avatar
twokbolt
Dorman makes a nice magnetic oil pan bolt that fits our cars. Part # is 65372
Old Oct 4, 2017 | 06:52 AM
mfi's Avatar
mfi
The mechanic said some people put a little skid plate over that area.
Old Oct 4, 2017 | 12:28 PM
That’s a new one to me, but not saying it can’t be done.
I’ve had three C5s, all at stock height, and never had a problem with the oil drain bolt getting scraped up from bottoming out or hitting something. Just saying.
Old Oct 5, 2017 | 06:40 AM
mfi's Avatar
mfi
Maybe something hit it..lot of roadwork going on round these parts.
Old Oct 5, 2017 | 07:54 AM
runner140*'s Avatar
runner140*
Curious where you are from...you didn't fill out info page?
My 2000 is slammed all the way down, but I never scraped the oil pan or bolt.
Old Oct 5, 2017 | 12:09 PM
mfi's Avatar
mfi
Stamford CT...they scarified a lot of the roads..also lot of speed bumps.
Might have been the previous owners so who knows.
Old Oct 5, 2017 | 08:34 PM
bluestreak63's Avatar
bluestreak63
Speed bump. If you hit one too fast, the front end slams down right around where the drain plug would be.
To Oil pan bolt
