I got the C5 battery partition from vettenuts today. There are three holes for bolts, screws, washers, nuts, or whatever to attach it to the car. Does anybody what the sizes, lengths, threads, etc, said hardware is/are?
Got the thing installed. Took out the battery to make it easier, so wouldn't ya know it, I stripped out the negative terminal bolt and had to get another one to replace it. Got that fixed too so that's enough for today before something else goes bad..
Understand totally. Yesterday I was installing halo tail lights. Removed old tail lights and installed 3 halos in about 20 min time (including weatherstripping around the halos); the last took nearly an hour! Needed to install the hyperflash harness, but didn't want 3 of 4 screws to go back in easily and then have problems with the 4th so figured it'd have to wait.
I could tell you stories but it would take the better part of a week to write them all down. As you probably know! If things are going wrong, odds are they aren't going to get any better.
