Brake lights
Old Oct 7, 2017 | 12:41 PM
Black76's Avatar
Black76
Default Brake lights
I have a 1999 the driver side brake lights are out both lights . how does it work if one bulb is out both dont light on that side or have i blown both brake lights also what is the part number for the brake light
Old Oct 7, 2017 | 12:50 PM
CJ1957's Avatar
CJ1957
Maybe more than you need but here you go:
Rear Turn Signal
3057
3057LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail Light
3057
Stop Light
3057
High Mount Stop Light
Assembly
Old Oct 7, 2017 | 01:06 PM
Black76's Avatar
Black76
ok i just verfied its not the bulb i switched out side tailouts from driver to passenger side passenger side works driver side doesnt so its not the bulb but what ae the odds of both sockets going bad on the driver side
Old Oct 7, 2017 | 01:37 PM
Black76's Avatar
Black76
Originally Posted by 8VETTE7
Use a digital multi meter to see if you are getting voltage to the turn signal/brake wire on the drivers side.
Yellow wire is the turn signal/brake wire.
If no voltage the problem is in the multi function stalk (MFS) a somewhat common failure item in the C5.
what is the MFS and where is that located
To Brake lights
