[Z06] "Service Active Handling Module"
Old Oct 10, 2017 | 09:18 PM
63Corvette's Avatar
63Corvette
Default "Service Active Handling Module"
Service Active Handling Module".............What are my options for this?
Old Oct 19, 2017 | 03:27 PM
Alexander K's Avatar
Alexander K
Disregard. Posted in wrong post
Old Oct 19, 2017 | 03:31 PM
Camarohoss's Avatar
Camarohoss
Cruising
Just posted on how I was able to fix. Turned out to be bad solder joints on the power leads. Resoldered and now works as it should.
Old Oct 20, 2017 | 07:54 AM
Efx's Avatar
Efx
Thanks for the pics. Could be my issue as well.
Old Oct 20, 2017 | 11:02 AM
dork's Avatar
dork
Camarohoss,
Where is the circuit board that you pictured? If I ever have this problem, I'd like to know where to find that board. Thank you.
Old Oct 20, 2017 | 07:22 PM
Camarohoss's Avatar
Camarohoss
Cruising
Originally Posted by dork
Camarohoss,
It is on the drivers side attached to the ABS block where all the brake lines come in to it (look down ahead of the alternator above the steering rack) The control module is attached by 4 screws and has harness tied in to it. Once removed from vehicle you need to carefully cut thru the sealant with a razor blade. Be carful not to cut to deep.
Old Oct 21, 2017 | 09:52 AM
dork's Avatar
dork
Thanks again for taking the time to post in both threads I queried!
Old Oct 22, 2017 | 11:04 PM
Camarohoss's Avatar
Camarohoss
Cruising
You bet!! I’m pretty knowledgeable when it comes to the corvette and hope I can share from my experiences and help others.
Old Oct 23, 2017 | 07:10 AM
555ss's Avatar
555ss
I have done the joint repair to many units but Code 1255 I sent to Brandon at ABSFIXER
the unit needed to have a few solenoids replaced. 2 weeks later the other car did the same thing we run them HARD and with track use he said this happens it was like $170 with shipping and I had them back in a about week for each one.
To "Service Active Handling Module"
