Check Engine Light
2003 50th Anniversary Coupe, 6 speed manual, purchased brand new. The exhaust system shown is exactly like mine. I have a CEL code: P0430=catalyst efficiency below threshold. It could be the downstream O2 sensor or the cat. I know the two oval "canisters" are cats. Does anyone know what the smaller round "canisters" are at the front of the exhaust? Are they cats, mufflers, resonators, or WHAT???
It is stone stock and I want to keep it that way. I DO NOT want to remove the cats or add headers. This is a daily driver and I simply want to pass my state's emissions test or they will make me a daily walker. Thanks.
I agree that it is the left side. You can have someone hook up to the computer to determine which is bad (cat or sensor). If the cat is bad, the 2nd O2 sensor will track the 1st sensor nearly identical. My cat was toast after 250k miles. I had the rear O2 sensors tuned out.
I would assume the pup cats have the same materials in them as the larger cats. They are just closer to the manifolds so they heat up faster. They likely can fail as well.
It is stone stock and I want to keep it that way. I DO NOT want to remove the cats or add headers. This is a daily driver and I simply want to pass my state's emissions test or they will make me a daily walker. Thanks.What you want to see is a high frequency on the front O2s & closer to a flat line on the rear O2s. New clean O2 sensors will likely be more responsive than old ones. I would NOT replace a rear O2 for a PO420/430 code for this reason.
The atached photo shows Graphs from B1&B2 O2s. Bank1 (top 2graphs) is working well, but B2 (bottom 2) cat is DEAD
I needed gas for the car so I got it filled up (CEL still on). I decided to clear that code and take it for a ride and keep the engine RPM at mid-range. Drove on the freeway using 3rd and 4th gear only for about 30 miles. I kept Rpm to around 2500 to 3500 as much as I could. Got back home and no CEL!! Still hasn't come back even after a 150 mile trip.
So I wonder if that higher RPM driving I did helped to clean everything up both inside the cat and the bank 2 sensor? Do short trips tend to cause clogging the car or getting carbon on the O2 sensors?
