It’s not a bad price for six quarts, and even better if Costco happens to be included in the rebate offer. They are not listed in that link above, but neither was Wal-Mart.
As I understand it, Mobil 1 changed their formula a few years back and are no longer "recommended" for use in LS engines (this, according to the hot rod shop owner who works on my car).
I used to use Mobil 1, now I use Amsoil. I see a difference on the drain plug (less shrapnel/shearing) during oil changes, FWIW.
It is true that Mobil 1 is not the same as when our cars came out. It used to be made of Class IV stock (which is 100% lab made synthetic). Several years back they switched to Class III stock (which is very refined dino oil).
Only a few oils use Class IV stock now, I believe Amsoil is, as well as Pennzoil Ultra Platinum.
I usually use the ultra platinum, it's the same price as Mobil 1 and they have a $10 rebate as well.
Honestly I don't think it matters at all - any full synthetic is excellent.
man this always confuses the hell out of me, my 2004 Z06 with 25K miles on the clock, i have only used Mobil1 but since i am now driving it more i want to put the BEST oil in it and not base my decision on price.
So which one should i use ???
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by feeder82
Mobil 1 is still the factory recommended oil for new corvettes, including the 650hp ZO6 so why not
I use it in my new Z06. It is Dexos approved and recommended for the Z. I have used it in all of my newer Corvettes over the years. Never had an issue. People waste alot of money on "boutique" motor oils. I've seen many an LS motor go over 250,000 miles on Mobil 1. This is the most over discussed topic on any of the Forums. Do what makes you happy, but the boutique motor oils will only lighten your wallet.
Mobil 1 5W 30 in this:
Mobil-1 is Dexos approved and the current bottles (either 1 quart or 5 quart) also shows the oil meets the old GM 4718-M standard. That standard began with the introduction of the Corvette LT1 engine starting in 1992.
The Corvette engine plant still fills all of the Corvette engines with Mobil-1. There should be no reason to not use the Mobil-1 oil you see on store shelves today.
So to answer the question posed by ZEEZERO6" So which one should i use ???, the answer would be Mobil-1 5W-30.
I bought the five quart bottle from Walmart for $22.88, and just got my $12 rebate check.
Same here, bought 2, I used to buy the 6qt case at Sams Club I think it was $35, and I purchased 4 single qts from Napa when it was on sale, makes for a cheap oil change.
