Found This Bulb On The Driver Side Floor
Old Oct 20, 2017 | 07:02 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
Default Found This Bulb On The Driver Side Floor
Anyone know what this little blue bulb is for?
Found it on the driver side foot well carpeting as I was about to vacuum the interior.
Car is a 2002 Z06.
Silverbird
Old Oct 20, 2017 | 07:16 AM
chris308's Avatar
chris308
Previous owner did LED swap in all of the interior buttons i.e door switched, DIC, A/H, etc... must have dropped an OEM one.
Old Oct 20, 2017 | 08:00 AM
silverbird's Avatar
silverbird
St. Jude Donor '08
Nope, I'm the previous owner.....There was no LED swap.
Everything seems to be lighting up.
It might take a while to figure out what this bulb is for and/or where it came from.
Thanks,
Silverbird
Old Oct 20, 2017 | 08:51 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Isn't "high beam" blue?
Old Oct 20, 2017 | 09:47 AM
pjdbm's Avatar
pjdbm
one of the DIC bulbs or door bulbs. Just check closely which one is missing or out
Old Oct 20, 2017 | 12:30 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Thanks to all.
Hopefully the door....Much easier to get to.
Silverbird
Old Oct 20, 2017 | 12:37 PM
zachaeous's Avatar
zachaeous
There is a bulb like that in the traction control panel that is located in the front on the console compartment.
Old Oct 20, 2017 | 01:13 PM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
That's a T4 Neo Wedge bulb. Used for the Active Handling button (lights it up) but believe these types of bulbs are used elsewhere in the car. If you search the forum for 'T4 bulb' you should see what the possibilities are.
Old Oct 20, 2017 | 01:40 PM
Tsumi's Avatar
Tsumi
Fog/trunk button, active handling, door switches, DIC and HUD buttons, and possibly radio and climate control.
Old Oct 20, 2017 | 01:42 PM
mrlmd's Avatar
mrlmd
I found a bulb like that on my floor too, it was the top bulb of my DIC gauge buttons, and I had never been in there before, it just spontaneously appeared on the floor near the gas pedal. What a PIA to replace it.
Old Oct 20, 2017 | 03:21 PM
knewblewkorvette's Avatar
knewblewkorvette
Considering you found it on the driver's side floor, my bet is the trunk/hatch button light bulb. If it is, easy to put back in. If it's a DIC bulb, well, that's more of a bitch to do.
Old Oct 20, 2017 | 03:32 PM
Hope you find where the bulb came from - sounds like a lot of possible locations.
Old Oct 21, 2017 | 12:49 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Found it....DIC buttons....#1 "FUEL" and #2 "GAGES" buttons are dark.
Wondering if these 2 are lit by one bulb or two?
Does the gauge cluster have to be unplugged and completely removed to access these bulbs or can you tilt it forward enough without unplugging to remove and replace the bulb.
Silverbird
Old Oct 21, 2017 | 02:16 PM
zachaeous's Avatar
zachaeous
Yes one bulb per two buttons. I removed the cluster completely to change the button bulbs to LEDs. If my memory serves me the bezel has to come completely off the cluster to access the bulbs.
Old Oct 21, 2017 | 04:22 PM
GCG's Avatar
GCG
Old Oct 21, 2017 | 06:26 PM
knewblewkorvette
yep on all counts
Old Oct 23, 2017 | 01:11 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
Looks like there's a dash teardown in my future.
I'll be doing the LED bulb upgrade.
So there are 3 bulbs for the DIC buttons and 3 bulbs for the HUD control on the opposite side?
Thanks,
Silverbird
To Found This Bulb On The Driver Side Floor
Old Oct 23, 2017 | 02:49 PM
pjdbm's Avatar
pjdbm
yes, you can buy a whole kit that includes most of the bulbs
remove battery cable before you start
Old Oct 23, 2017 | 03:14 PM
zachaeous's Avatar
zachaeous
I purchased my set from here JW Motoring, a forum vendor. $20.98 shipped for the whole set.
http://www.jwmotorsportsllc.com/C5-H...Kit_p_161.html
Old Oct 23, 2017 | 03:36 PM
Tsumi's Avatar
Tsumi
Which is really a ripoff. Those LEDs are $7 for 20 on Ebay.
