Corvette Engine Deep Clean
Old Oct 27, 2017 | 10:22 AM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Corvette Engine Deep Clean
Old Oct 27, 2017 | 11:45 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Good.......but would be better with a proper brush, to get in all the tiny crevasses.
Old Oct 27, 2017 | 12:25 PM
chris308's Avatar
chris308
I basically do the same but remove the rad/condenser cover to flush out debris in there, as well as scrubbing and washing the hood panel cover. I also stick the hose down by the udders and flush leaves and crap out from the fender areas.
Old Oct 27, 2017 | 12:31 PM
Chris Draper
Yea that is my next task. I already cut the video down from 30 min to 15 So that may be another video.
Old Oct 27, 2017 | 02:09 PM
grampi50's Avatar
grampi50
Nice video. FWIW, I love the Super Clean, but I prefer the liquid spray to the foaming spray. The liquid seems to get into the small areas better than the foam does. Also, something the guy in this video didn't mention, you want to make sure the engine is absolutely stone cold before you spray this stuff on, otherwise it will dry quickly and then it can't be rinsed off. It's best to leave the vehicle parked overnight before spraying this stuff on...on a side note, I would never buy a C5 with an engine bay this dirty. This is a sure sign of neglect...
Old Oct 27, 2017 | 02:40 PM
1Willy1's Avatar
1Willy1
Ive been using the heavy duty simple green concentrate with a pump action pressure sprayer designed for watering flowers and gardens, it works amazing and is cheap as hell .
The long spray nozzle gets into any crevice , even the deep ones, really great little tool and only like $15.00 at any hardware store
Old Oct 27, 2017 | 03:55 PM
Chris Draper
If it were not for the service records the guy kept, I would not have bought the car. The exterior and interior looked just as bad the day I test drove the car. It was his daily driver. He was a military guy based in Virginia. He just drove the car across country when he was re-stationed at Twenty-Nice Palms, CA.
Old Oct 27, 2017 | 04:28 PM
Rob 02's Avatar
Rob 02
You have been putting out some good video lately.
Keep it up.
Old Oct 27, 2017 | 09:23 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Pull the radiator cover (the 4 10mm bolts) and you'll see Armageddon clinging to the radiator.
Also, under the intake manifold is an equal number of Democratic operatives waiting to be removed.
Old Oct 28, 2017 | 12:02 AM
Heck of a difference in the before and after shots of that engine.
Old Oct 28, 2017 | 07:12 PM
Chris Draper
Intake manifold?
Old Oct 28, 2017 | 07:27 PM
Rob 02's Avatar
Rob 02
Originally Posted by Chris Draper
Intake manifold?
With mine, and every other LS engine I have seen with the intake manifold removed, has trash under the intake on the valley cover.
If you were to ever disassemble the engine you would find dirt in every nook and cranny. Not much you can do about that.
Your engine looks great BTW. Vast improvement.
Old Oct 28, 2017 | 07:42 PM
CactusCat's Avatar
CactusCat
Classic!
Old Oct 29, 2017 | 01:40 PM
xtremeyolks's Avatar
xtremeyolks
Very nice! I need to do this to mine too.
Old Oct 30, 2017 | 02:33 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
What happened to the "motor doesn't like water" theory???
Old Oct 30, 2017 | 04:56 PM
Chris Draper
Depends on the car really. Like the C4s with Optispark I could think twice before using water. But as long as the engine is cold and you cover the crucial electrical stuff it's ok.
Old Oct 30, 2017 | 05:16 PM
mre1974's Avatar
mre1974
I do almost the same thing...I use Simple Green usually mixed 2 parts Simple Green to 1 part water, spray the engine bay and let it set awhile before hosing it off. Usually works pretty well at getting most of the sand and other grime out of my bay.
Old Oct 30, 2017 | 05:56 PM
Mayor111's Avatar
Mayor111
Thank you for the great video. I wanted to share a product I use to get my engine compartment ready for car shows.
So I happen to use Simple Green and mist off with water to get the dirt off the engine then use a blower to dry off the water, then go for a quick drive to get out any remaining water/moisture.
Then I spray my engine with CDN spray. Its completely safe around electronics, plastic, metal, rubber, etc. I use it in my door jams, wheel wells, any place I need a shine that isnt sticky or greasy. I order a case from the guys in my Corvette Club, but if interested, here is the name and number on the back of the can: CDN Distributers - 570-457-1960
This was taken AFTER using CDN and driving 120 miles...(this stuff lasts)
Old Oct 31, 2017 | 10:10 PM
AwesomeC5's Avatar
AwesomeC5
Great video...what a huge difference!
To Corvette Engine Deep Clean
