Radio Replacement?
Old Nov 12, 2017 | 07:38 AM
my01vette's Avatar
my01vette
Default Radio Replacement?
I would like to replace my factory radio with something my android phone will Bluetooth to. Whats involved and any recommendations?
Old Nov 12, 2017 | 09:32 AM
GCG's Avatar
GCG
To properly replace just the head unit leaving the rest of the system in place you will need an adapter (not just a harness) to provide the required interface. This is due to the way the factory system was designed.
The 2 most common adapters are:
Replacing the head unit should be just plug-and-play by using either one. Both have setup adjustments to customize sound/levels. After tweaking them to your liking, they shouldn't require any further touching.
A double DIN is very nice, but if budget doesn't allow it and you want to consider a single DIN, then you would need an adapter plate to secure the new unit in place and provide a nice finish.
Here is an adapter plate that matches the interior very well. It has the word "Corvette" engraved in it that can be set up with backlighting (or you can customize the lettering).
From their website:
CNC machined aluminum faceplate, finished in either a fine black texture finish or brushed aluminum.
The lettering can be above or below the head unit opening, there is also a non illuminated version with the head unit located in the center of the mount.
The main lettering illumination available in red, blue, green, yellow, white LED’s and also red mini lamp illumination.
Custom lettering and design is available.
