C5 front will not lower, how is this possible?
My father has a 2004 ZO6 lowered on stock bolts, with the front bushings cut in half and his front front fender arch from flat ground is literally an inch lower than mine, How is that even possible? wheel/tire diameter are identical.
Here's everything leading up to where I am now,
First I lowered the car by turning the stock bolts down, it was lower but still very 4x4.
I took a drive up to WCC and got a set of lowering bolts font and rear. Install was very easy, the rear was dramatic, actually too low the first time I set it down (almost tucking tire) I had to raise it an inch or two. The front, completely maxed out on the lowering bolts, was barely lower than it was on stock bolts.
I let the car settle for a week, it is my daily so it definitely had more than 100 miles put on it, the next weekend after reading some threads on here I decided to completely remove the front bolts all together, I used a thin sheet of rubber material in between the leaf spring and control arm to keep any contact noise minimal. I read that after removing front bolts people were "scraping road reflectors" with their front air scoops, mine doesn't even scrape backing straight out of my driveway.
As I said I'm ordering a set of coilovers early next month, which I know will solve the lowering issue and allow for more adjustment in all aspects, but just what in the hell is keeping mine up so high?
Heres a crappy side shot but should show it pretty good. Its reverse raked, going to crank up the rear end more until I get coilovers it seems like.
But again just don't get how my fathers measures one full inch lower than mine
get some taller wheel/tire combo on the rear, or coilover can fix that or both
and the only way to decrease the front gap is coilovers
Now just what ones to get!
As for the tire combo my ccws are 17/18 stock width, running stock tire sizes, I heard if I went up to a taller sidewall it would mess with the traction control system?
About to order some coilovers, have some sway bars ready to go in at the same time. Was really just curious as to how my dads 04 Z is an inch lower with stock bolts, bushings cut, whereas mine has literally zero bolt to hold it up
hahha i missed that, 80 to 100lb iron block, and blower set up would be sure to help
coilover is the way to go
I cant answer that, I have mine permanently turned off, and no ABS also
