dic repace lights
https://www.ebay.com/itm/corvette-97...RYcUgD&vxp=mtr
you can choose green or red white & blue.
JWM used to provide a simple shematic to test the bulb’s polarity before replacement using a 9 volt battery. If I can find my copy I will post it here. I got my bulbs from Superbrightleds.com.
There is a big HOWEVER when doing this. Replacement bulb quality varies. The key problem, which one can visualize above is the thickness of the base. In some, the base is thicker and if forced into the socket will crack the circuit board which forms the socket. On my Z, I attempted to make the base thinner by removing the led itself and sanding the base. It worked ok, but then after examining the oem and replacements, I saw the layout was identical. As also pictured above, I removed the original tungsten bulb and replaced it with the led. Worked seamlessly.
Summing up: I’ve had some neo wedges go right in, others after mods of their base and others involving the described ‘bulb transfer’. I’ve never had a problem with them afterward and highly recommend this mod as a fun way to ‘wake up’ the interior. Even if you go with white, it still looks a lot better than the weak stock bulbs.
One last caveat: the bases have a straight ‘screw slot’ to ease install/removal. They usually get distorted from the pressure needed to turn the bulb. I gave up and use a fine pointed needle nose plier inserted into the 2 holes where the wires go thru. Allows easy turning, and assists in removal and placement of the bulbs. Just don’t turn to hard!!
with the needle nose method. A flathead chews up the soft plastic on the bulbs.
