"Battery Tender" question/issue???
Pulled out the instructions and they say:
THE RED LIGHT COMES ON WHEN STORAGE
CHARGING BATTERIES:
a. The battery may be defective, take battery to the
dealer to be tested.
b. The battery has an excessive current draw, remove
battery from equipment.
The battery is a year and half old Delco. Anyone seen this before?
Thanks.
You'll still want to know about current drain with the car totally asleep; easy with a suitable ammeter momentarily in series from disconnected battery post to cable or using a clamp style ammeter. Someone here should post the 'normal' milliamp reading.
Loose or corroded connections, including grounds, are oft the problem while expensove to have a 'pro' find. Sometimes, it's an e-module at fault, but watching for a drop in high 'asleep' current, while systematically removing each fuse, can be a great step forward. Corrosion increases resistance to electron flow, but increases the current, which can damage sensitive components, even light bulb filaments, as trhe battery attempts to maintain rated voltage.
V=I/R or VR=I are simple equations, comprised of Voltage, Resistance and current(I). Alter the resistance; see the effect on current, with voltage constant. Too-small wires is similar and, according to my mechanic pal, is why so many newer cars have lights that don't light.
It is so hard to find a quality battery anymore, thoguh I've not used Delcos for a few decades. despite a great experience then. The lead content is minimal in most and they're made south of Texas.
When first connected, mine will be solid red, while it is measuring. When voltage is almost where it should be the red will stay solid and green will start flashing for a short time until it turns solid green and red goes off. Any time there has been drop in voltage issue the red will indeed illuminate, but green has always gone off completely.
If all is working correctly the battery tender should have a float voltage somewhere between 13.3 - 13.5. Your voltage is close so your tender is probably trying to get there but not succeeding.
Taking it tomorrow to have it load tested.
30 month free replacement and I'm within that window and have the receipt.
Off to the Chevy dealer in the AM.
dave
