Stock Suspension upgrade?
Old Nov 21, 2017 | 08:14 AM
  #41
MatsA's Avatar
MatsA
2024 C6 of the Year Finalist - Modified
Originally Posted by chasboy
By that theory a Citroen 2CV should outhandle a Corvette, and a stock Z06 should have a softer suspension than the base coupe. I think what’s missing here is the absence of the EXTENT of stiffening that a different piece of equipment will provide, as evidenced by your own choice of suspension components.
Yes a Citroen 2CV actually do outhandle a Corvette, you can turn into a corner with 5km/h and huge body roll and clear the corner perfect still with 90 km/h in the same corner it will have the same amount of body roll and clear the corner perfect
By the way i went with C6Z06 shocks and Steinjager something swaybars 1.25 front 1.0 back on my 02Vert
Old Nov 21, 2017 | 12:01 PM
  #42
chasboy's Avatar
chasboy
Oldtimer
Ok, I’m going to pull the trigger on an set of c6Z06 sway bars. Who’s got the best deal?
MatsA, I’m sure that driving the Citroen like that is a great thrill!
Old Nov 21, 2017 | 12:10 PM
  #43
Tsumi's Avatar
Tsumi
Unless you're running Z06 size tires, I would recommend going with C6Z51 sways.
Cultrag seems to have the best deals.
Old Nov 21, 2017 | 04:56 PM
  #44
Yello95's Avatar
Yello95
St. Jude Donor '11
Got mine from Gene at Cultrag...in comparison it feels like im riding on rails...not much lean compared to what it use to feel like...I am happy with mine and I think you will be also...
I got the poly bushings but they seem to creak and squeak a bit so I will be changing to OEM stock bushings soon...
Old Nov 21, 2017 | 05:00 PM
  #45
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by typeav
For street car stay away from "Polyurethane Bushing" it make the suspension even more stiffer with all kind of noise coming out of it.
Stick with GM insulators
...ask me how I know...switching soon..
Old Nov 21, 2017 | 05:02 PM
  #46
Yello95's Avatar
Yello95
St. Jude Donor '11
Old Nov 21, 2017 | 05:23 PM
  #47
chasboy's Avatar
chasboy
Oldtimer
I’ve been in touch with Gene. Poly bushings used to be the go to for 4x4 applications too, renowned for noise.
Did your ride characteristics change at all?
Old Nov 21, 2017 | 06:37 PM
  #48
Rob 02's Avatar
Rob 02
My stock bushings were so worn that I couldn't get a good alignment and the car would tram line like crazy.
I had to go with poly. I can only compare them to worn bushings. There is more road noise and a bit harsher ride but overall I like the way it handles. I don't have much noise but the grease fittings probably help. I also have some interior sound deadening.
I like hearing what others think of them as well.
Old Nov 21, 2017 | 08:47 PM
  #49
and_hvac's Avatar
and_hvac
6th Gear
GT2 coil over and G1 Sway bar package, I thinking about this coil over kit. I like to know if anybody install one on a C6 base?
Old Nov 21, 2017 | 08:54 PM
  #50
Tsumi's Avatar
Tsumi
You really should ask this question in the C6 forum, not the C5.
Old Nov 21, 2017 | 11:38 PM
  #51
Yello95's Avatar
Yello95
St. Jude Donor '11
steering is more responsive...front end does not lean on tight turns and curves like with stock sway bars...love the difference....and that's just with the addition of the C6Z51 sway bars...next on my list will be changing to metal sway bar links to replace the stock plastic links...
Old Nov 24, 2017 | 12:34 PM
  #52
FASTFATBOY's Avatar
FASTFATBOY
SO much misinformation in this post, WOW.
Put Used C5 Z06 springs and bars on the car with Doug Rippie valved Bilstien shocks on it with some 200 tread wear tires on it along with the Pfadt street tire alignment. 95% of drivers will never reach the limits of this setup.
Old Nov 24, 2017 | 01:08 PM
  #53
chasboy's Avatar
chasboy
Oldtimer
Only a matter of time now, ordered The C6Z bars as soon as the Black Friday sale started yesterday.
Old Nov 24, 2017 | 01:39 PM
  #54
FASTFATBOY's Avatar
FASTFATBOY
C6 Z bars are designed for a longer wheelbase car with a lot larger tire.
Do what ya want, just because it bolts on the car is not a good reason to put them on.
Most guys(if not all)in this post have no track experience in any car much less a C5.....along with zero knowledge of how suspension works.
C6Z shocks, bars and springs were designed and valved for a C6Z, not a C5.
Old Nov 24, 2017 | 03:59 PM
  #55
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I agree with you for the most part, but it will have little affect on the street driven under normal conditions. It would be noticed at the track under heavy load.
Old Nov 24, 2017 | 07:26 PM
  #56
chasboy's Avatar
chasboy
Oldtimer
Well, I’m only doing the bars, I do have track experience and have discussed this mod with a number of very knowledgeable people. thanks for the input.
Old Nov 25, 2017 | 12:23 AM
  #57
Yello95's Avatar
Yello95
St. Jude Donor '11
you will love the difference in handling on corners and quicker response and no lean...
Old Nov 25, 2017 | 09:04 AM
  #58
JHrinsin's Avatar
JHrinsin
The C6 Z06 (rear) bar maybe... but if you are both running a +400rwhp power level with C5 Z06 wheel sizes and 295 or wider rear tires on your C5, then the differential is a lot less than you think.
But the C6 Z51 bar combo has a very similar K factor ratio as the C5 Z06 bar combo. The C6 Z06 shocks are also very similar to the '04 C5 Z06 shocks and most could not tell the different in a blind back to back ride/handling comparison test of new vs. new shocks. Plus currently the C6 parts seem to be less expensive. So what's not to like?
By Michael S. Palmer | 2026-06-03 09:39:05
