Bose Stereo Question
Old Nov 21, 2017 | 09:00 PM
jost6453's Avatar
jost6453
Default Bose Stereo Question
Is there an adaptor for 'plug in' ..... or any way to modify the OEM Bose stereo unit to accept bluetooth so I can play music from my iPhone? I want to keep the OE look, but would like better functionality.
Old Nov 21, 2017 | 09:23 PM
dmarkshark's Avatar
dmarkshark
I don't think you can do bluetooth, but there is an adaptor that you can buy that will let you do a I-phone plug in.
Old Nov 21, 2017 | 10:04 PM
jost6453's Avatar
jost6453
Plug in would be great. Any idea where I can get the adaptor?
Old Nov 21, 2017 | 10:10 PM
jrprich's Avatar
jrprich
Google is your friend
https://www.google.com/search?q=add+...hrome&ie=UTF-8
Amazon Amazon
Old Nov 21, 2017 | 10:15 PM
Cosmic Charlie's Avatar
Cosmic Charlie
they sell a fake cassette that is a bluetooth receiver
they make a plug in - to the trunk 12 disc unit that will give you a 3.5 mm line to you phone or a mini bluetooth receiver
and this will plug into the back of your radio ... to set up a mini bluetooth receiver or 3.5 mm plug
Amazon Amazon
other choices as well
just depends what you have now (you didn't say - cd , 12 cd, cassette) how much work your willing to do
Old Nov 21, 2017 | 10:16 PM
glbeauchamp's Avatar
glbeauchamp
I installed one like jrprich has a link to. Haven't used it yet.
Or maybe this?
Amazon Amazon
Old Nov 22, 2017 | 08:48 AM
jost6453's Avatar
jost6453
Thanks guys, I appreciate the feedback. I'm no electronic wiz so wasn't sure what to even search for. I'm not exactly sure what I have .... just got the car. It does not have a cassette. It does have a CD I'll check out the option that have been provided. I'm not afraid to do some work to get a system that has good sound and functionality. So additional comments regarding quality and customer experience are appreciated.
Old Nov 22, 2017 | 10:19 AM
funnyguyMI's Avatar
funnyguyMI
Do you have the CD changer in the trunk? I think you need that from the factory for the CD changer/iPhone/pod cable to work. I have that in my car and it works great. Charges the phone too!
Old Nov 22, 2017 | 03:39 PM
glbeauchamp
I'm fairly sure if your car is equipped with a remote 12 cd changer, the changer cable has to be disconnected from the back of the radio control head and the peripheral aux adapter plugged into the now empty aux cd plugin. If you do not have a remote cd changer, the cd aux plugin should be empty already. But I could be wrong about that.
The installation is fairly straightforward. You just have to remove the console and the radio control head. If you decide to use the aforementioned peripheral, it plugs into the aux/cd plugin. The peripheral will have to be set with rocker switches in the back of it to the car. A list is supplied with the unit.
Old Nov 22, 2017 | 03:47 PM
Cherry3m's Avatar
Cherry3m
Just get this. I have it plugged into the console power outlet. Works great.
https://www.amazon.com/gp/product/B073S62S65/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B073S62S65/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Old Nov 22, 2017 | 04:20 PM
03WhiteConv's Avatar
03WhiteConv
If you have the CD Changer in the trunk you DO NOT have to pull the radio. iSimple makes a device that plugs into the changer harness in the trunk. It is called PXDX and you will need the PXHGM2 harness. That will allow you to tap into the audio system with a headphone type plug or get input to a red/white RCA plug.
For Bluetooth with handsfree calling you could try the Besign BK01 Bluetooth 4.1 Car Kit or the newer one BK03. We used the BK01 in our BMW and it worked well. You'll also need a female-female 3.5mm coupler to connect the Bluetooth device to the input. Or you could use the RCA inputs and connect it with an RCA to 3.5mm (female) adapter.
Old Nov 22, 2017 | 06:02 PM
glbeauchamp
Good to know. I don't have the changer so I didn't have to think about it.
Old Nov 22, 2017 | 09:44 PM
jost6453's Avatar
jost6453
No changer in the trunk.
Old Nov 23, 2017 | 11:22 AM
Allieboy's Avatar
Allieboy
http://www.discountcarstereo.com/AUX-GM2.html
Works great
Old Nov 23, 2017 | 11:54 AM
jost6453's Avatar
jost6453
Originally Posted by Allieboy
thx.... but it says for use with a CD changer ..... which I do not have.
Old Nov 23, 2017 | 12:10 PM
glbeauchamp
check this out. It should work
Amazon Amazon
Old Nov 23, 2017 | 12:17 PM
redzg's Avatar
redzg
$100, and an hours time:
https://www.ecklerscorvette.com/corv...1997-2004.html
Old Nov 23, 2017 | 04:31 PM
jrprich's Avatar
jrprich
Not so, I use one in my 03 and it never had a rear CD changer.
Old Nov 24, 2017 | 09:42 AM
Cosmic Charlie
https://www.moderngenauto.com/C2-C3-...0comcast%2Enet
To Bose Stereo Question
