[Z06] Traction Control
Old Nov 24, 2017 | 03:01 AM
Haynboy8's Avatar
Haynboy8
Default Traction Control
How intrusive is traction control? This is the second time that I felt the back end of the car get very loose when I did a 2nd gear pull. The first time I thought it was because I had a flat rear tire but I fixed it before driving it tonight. The car is cammed but will traction control still allow you light the tires up? Or is my traction control not working? I didn't see any lights flashing on my dash and no trouble codes.
Old Nov 24, 2017 | 06:34 AM
bikeriderga's Avatar
bikeriderga
Originally Posted by Haynboy8
How intrusive is traction control? This is the second time that I felt the back end of the car get very loose when I did a 2nd gear pull. The first time I thought it was because I had a flat rear tire but I fixed it before driving it tonight. The car is cammed but will traction control still allow you lite the tires up? Or is my traction control not working? I didn't see any lights flashing on my dash and no trouble codes.
What tires do you have on the car?
Tires make a huge difference.
Old Nov 24, 2017 | 07:08 AM
Haynboy8's Avatar
Haynboy8
Bridgestone RE760 sport, stock tire size. Not the best tires. I was just reading a thread and it sounded like the traction control will allow some wheel spin when the car is in a straight line.
Old Nov 24, 2017 | 10:53 AM
Spaceme1117's Avatar
Spaceme1117
It will let you spin the tires then kick in and reduce power. If I want to do a quick acceleration, I turn it off.
Old Nov 24, 2017 | 11:22 AM
Acid666's Avatar
Acid666
I've had a little interaction with the traction and stability control during autocrosses. I used to run in competition mode, but after it limited my rpms at one event I started running with none of the nannies on at all so I had full control of it.
It kept doing it coming out of a right/left transition where I was flooring it but the centripetal force was pushing me to the left. I didn't really feel any wheel spin or anything but it kept limiting the rpms and I wasn't hitting the rev limiter.
I just turn it off completely now and have learned to control myself around the course. On the street I don't really get on it much, but when my wife co-drives the car she drives with full traction control on and there's been a few instances where it's limited her but it'll still allow a little bit of wheel spin.
Here's what it was doing to me for reference.
Old Nov 24, 2017 | 12:12 PM
zeevette's Avatar
zeevette
My car is heavily modified, and there seems to be no TC or AH at all. No warning lights, and I just try to not give it more than 1/4" throttle in first or second. I see much stickier tires in my near future. I never race, and also never touch the TC button. No codes or warning lights, either.
Old Nov 25, 2017 | 09:09 AM
PeterC3's Avatar
PeterC3
I track my '01 Z06 in competition mode, I can feel the system apply brakes at times and wish it wouldn't. I want to get a better sense of the cars and my limits with out interference. My mechanic can dig into the cars computers to completely turn off the traction control system, I'm going to try it next track season.
Old Nov 25, 2017 | 12:46 PM
dbgoodwin's Avatar
dbgoodwin
I've always been able to get quite a bit of tire spin in a straight line acceleration.
Old Nov 25, 2017 | 01:52 PM
insertclevername's Avatar
insertclevername
If you've had a tune, the TCS method may have been altered.
Old Nov 27, 2017 | 06:03 PM
63Corvette's Avatar
63Corvette
The traction control algorithm varies according to the transmission gear you are in. It allows LOTS of tire slip in 1st gear, and some in 2nd and 3rd. BUT..........if you are already spinning in 1st gear (rain or snow) and shift hard to 2nd, there will be NOTHING connected to the right pedal!
The remedy is to learn throttle MODULATION, and run right on the edge of tire slip, but not into wild tire spin.
Old Nov 27, 2017 | 08:12 PM
Riteaidkid84's Avatar
Riteaidkid84
https://www.youtube.com/watch?v=ljZZSO6bqVs
Cool! My wife would kill us both in my car. Your wife is a winner!
To Traction Control
