Time well spent.
Old Nov 26, 2017 | 08:13 PM
calguy's Avatar
calguy
Default Time well spent.
A year ago I bought the brass gear to replace the plastic one in the headlight motor.
Finally stop procrastinating, and did the job, yesterday, and finished today.
All in all, about an hour and a half total to replace it.
Let the epoxy harden overnight, and put the unit in this morning.
Thank Christ, no more grinding noise.
One other thing that was also fixed by replacing this gear was my fog lights.
When ever I just wanted the fogs on(like early evening), I would turn the switch to light them, but the headlight doors also raised at the same time.
Never had a problem until the plastic gear gave out.
Now everything is back and tightened down, and the fogs work perfectly without raising the headlight doors.
Before getting started on this, the first thing you should do is to remove the rubber bumper pictured.
It will give more room to get behind the unit to get at the bolts on the motor.
Mark the threads so when putting it back, it will be in the same position it was when you removed it.
As you can see. I marked the threads in blue.
Bob.
Old Nov 26, 2017 | 09:45 PM
Rob 02's Avatar
Rob 02
Old Nov 26, 2017 | 09:51 PM
am3gross's Avatar
am3gross
I need to do mine also, I am gunna do both at the same time. Where did you get you parts from? I have been looking online and they all pretty much seem to be around the same price.
anyways, glad you got yours fixed, I am sure there is a level of gratification getting rid of that damn noise!
Mike!
Old Nov 26, 2017 | 09:56 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Nov 26, 2017 | 10:04 PM
FX VETTE's Avatar
FX VETTE
Good for you B0b!
Old Nov 26, 2017 | 10:51 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Pics would've made the thread not so boring.
Old Nov 27, 2017 | 01:29 AM
Nice job with the DIY fix.
Old Nov 27, 2017 | 09:52 AM
Mistrezz 06's Avatar
Mistrezz 06
Old Nov 27, 2017 | 10:10 AM
runner140*'s Avatar
runner140*
I remember when I did mine, as soon as I completed one, the other went out. Do both.
Old Nov 27, 2017 | 12:21 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Originally Posted by runner140*
I remember when I did mine, as soon an I completed one, the other went out. Do both.
yep...
Old Nov 27, 2017 | 02:22 PM
knewblewkorvette's Avatar
knewblewkorvette
Mike!
Here you go
http://rodneydickman.com/catalog/index.php?cPath=33
To Time well spent.
