Bcm
Old Nov 28, 2017 | 10:32 AM
FunCar11's Avatar
FunCar11
Default Bcm
If you are having trouble with your DIC flashing check your Traction control and check your anti lock brakes,and everybody tells you that it is a $900 BCM that needs to be replaced, Take a cotton ball soaked in Alcohol and clean the chip on your key. Fixed my problem and saved $899
Old Nov 28, 2017 | 10:52 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
good to know but how did you figure that one out?
Old Nov 28, 2017 | 12:53 PM
JR-01's Avatar
JR-01
Originally Posted by funcar11
if you are having trouble with your dic flashing check your traction control and check your anti lock brakes,and everybody tells you that it is a $900 bcm that needs to be replaced, take a cotton ball soaked in alcohol and clean the chip on your key. Fixed my problem and saved $899
Electronic Brake Control Module, EBCM?
Old Nov 28, 2017 | 12:56 PM
friou's Avatar
friou
Thats interesting, have to keep it in mind. Thanks for posting!
Old Nov 28, 2017 | 01:00 PM
Corvette#2's Avatar
Corvette#2
BCM (body control module) is the box behind the passenger footwell.
Old Nov 28, 2017 | 01:22 PM
MikeG37's Avatar
MikeG37
I've heard cleaning the pellet is sometimes a remedy for a Pull Key Wait 10 Seconds message, but don't see how it'd have anything to do with brake/traction messages.
More likely getting an intermittent Traction Control/Brake message and just the process of pulling the key out, cleaning it, and restarting clears the message... until it pops back up in the future?
Old Nov 28, 2017 | 01:44 PM
JR-01's Avatar
JR-01
I know, but The EBCM controls ABS and traction control, not the BCM(body control module).
Old Nov 28, 2017 | 03:26 PM
Wouldn’t be surprised if the warning pops back up.
Old Nov 29, 2017 | 10:44 PM
msandym's Avatar
msandym
I had that problem . Got code 1226 , it was the connector behind front disk brake . Female side gets a little deformed . Easy fix , got info here !
To Bcm
