4 barrel sound!
Old Dec 12, 2017 | 11:27 PM
Gary Collins's Avatar
Gary Collins
Default 4 barrel sound!
I'm old school and admit to missing the sound of an unsilensed air filter on a 4 bl ! I love the Fuel Injection but miss the sound any advice? I am totally stock at this point!
Old Dec 13, 2017 | 08:46 AM
Velocity_Vette's Avatar
Velocity_Vette
Any open filter element ("cold air intake") is going to produce intake noises as the element is not enclosed in the box. Even hacking the stock box some will yield the same effect. Ultimately you'll hear intake sounds regardless of what type product you go with. Will it sound like what you're going for? No. It's more like a swoosh than a wooooooosh (worst description ever).
Old Dec 13, 2017 | 11:46 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...wish I could go back to that sound also but I recently put on a Blackwing air filter and a set of Z06 Titanium exhausts and I can hear a little more of the sound from the intake area and not be drowned out by the blah blah blah of the exhaust...I guess I can also hear it more because of the MCM S/C hood I put on...through the heat extractor opening on top...
Old Dec 13, 2017 | 03:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
maybe skip that thought and move to a beefier exhaust note to satisfy the old school need. the EFI is just too sweet to screw with
Old Dec 13, 2017 | 03:23 PM
Andrew's Avatar
Andrew
Cut a hole in the firewall and have the air pulled from the cab, you will then hear that old 4b sound. Found this out by accident. I am also a Jeep guy and hate those stupid snorkels. Real off road guys do not use them as they bash into rocks and trees and get destroyed very quickly. So, some reroute the air supply to the cab, to cut down on dust and to avoid pulling in water. After this, the Jeep sounds like it has a 4b.
I am a bit old school as well and also miss this and the sound of a carbed solid lifter BBC, now that cannot be replicated.
Old Dec 13, 2017 | 04:14 PM
bobs77vet's Avatar
bobs77vet
i am old school too...but not when it comes to EFI and roller lifters/cams....those things are too freaking sweet to give up
Old Dec 13, 2017 | 05:18 PM
Gary Collins
Agreed!
Old Dec 13, 2017 | 05:43 PM
jd911's Avatar
jd911
If you like intake noise (and I do, I mean I really do, fliptop air cleaners on Buick big blocks) this is about as good as it gets. Yes, i know it's sucking hot air and there is most likely no horsepower gain, but the giant vacuum cleaner sound and the deep bassy Vooooom when you feed in just a bit of throttle around town, gets me wet.
Jim
Old Dec 13, 2017 | 05:59 PM
zeevette's Avatar
zeevette
Dumbest thread ever.
Old Dec 13, 2017 | 07:58 PM
Gary Collins
Thanks for Your 2Cents worth, You know you didn't have to read it or post?
Have a great day!
Old Dec 13, 2017 | 08:50 PM
C908's Avatar
C908
Funny just the other day I was remembering how I flipped the air cleaner on my 74 Monte Carlo. It had a 400 engine but it was still a dog in comparison to my 68 Camaro putting out 500 horse.
Old Dec 13, 2017 | 09:54 PM
Groove Merchant's Avatar
Groove Merchant
Jim
Hi Jim,
Do recall who makes that intake and where you go it? Thanks!
Old Dec 13, 2017 | 10:53 PM
ALLEGRO's Avatar
ALLEGRO
Ah......nothing would howl like a GM big block and a Quadrajet !!
I have the two-element unit like those pictured and it does have a distinct howl, "similar" to the old carb sound.
Good luck
Old Dec 13, 2017 | 11:49 PM
1999corvettels1's Avatar
1999corvettels1
Good luck
I have a 396 big block chevy with a q-jet, in my 1965 C10 pickup, never really noticed any sound, maybe because it's already at high rpm with the TH400 and 3.73 rear gears?Do you need a quite exhaust to hear it? Maybe my exhaust is too loud...
Old Dec 14, 2017 | 12:38 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Have a great day!
Herehere
Old Dec 14, 2017 | 01:11 AM
Gary Collins
Flip the lid on Your air filter Then go for a ride!
Old Dec 14, 2017 | 01:49 AM
1999corvettels1
I'll have to try it!
To 4 barrel sound!
Old Dec 14, 2017 | 10:19 AM
jd911's Avatar
jd911
Originally Posted by Groove Merchant
Hi Jim,
Sorry, but I do not. It was on there, when I bought the vette.
Jim
Old Dec 14, 2017 | 07:44 PM
C52002Vert's Avatar
C52002Vert
Jim
IDK but it looks like
Amazon.com: C5 Corvette Dual High Flow Cold Air Intake Complete ...
Old Dec 15, 2017 | 02:00 PM
zeevette's Avatar
zeevette
Have a great day!
Doesn't change the facts. It's a FI car. I suppose you could find a spread bore intake and throw a Quadrajet on there. Yeah, that's not dumb...
