No return now... Ipad mod
Many got these super nice interior and than there is a old climate control that just ruins it.
Honestly I think the dash with upgraded audio almost looks worse than all 80's Chev. "Hey brand new looking audio unit... what's with that though!?" It amplifies (pun intended) how ugly the leftover is IMO.
Dash area = not bad looking
Radio = ugly
Heater controls = ugly
Somebody figure out a way to replace both with one unit and some sort of interface... a real tech savvy guy who used to work at my day job said he could do it (I believe it, he could modify the DOS, Access systems here way beyond what I thought possible).
Anyone has an idea what to do with this stupid cupholder? It kinda sucks and when im having the panel off maybe you could do something better or something else with it?
HB
I will post pics soon, just started puting the my piece together with fiberglass.
OP, clever idea, just wondering where the HVAC will go.
I like the soundman’s slide in kit.
I’d love to see the HVAC be replaced.
I’ve experienced the Tesla screen too, and it’s great.
Couple of things to consider:
Automotive Eq that we all complain about is pretty durable, and it works well below freezing for days at a time and up to 130 ish in heat.
Not Sure ipads or tablets can do that.
So as long as it goes inside with you when you park for more than a few hours......sure......the stuff today will do all the functions you need in one device.
We used to run front end software that made using the PC easy while driving (nice menues, big buttons....etc) you dont want to be reading small text while driving. But although I havent looked, Im sure its out there.....ANdriod Auto...Google has to have something and Im sure Apple does also.
My PC was mounted in the back on the wheel well, and the monitor slid out from the space under the stock head unit (I moved the heat/AC to the lower spot where the ashtray was). So I kept the OEM head unit and ran the audio input into that.
If you pop an ipad in there, or any tablet......Im pretty sure its not going to fit in front of the stock head unit (having had that apart several times.....theres no room). So you will need an amplifier that you are going to have to interface with the stock wiring harness for the radio. And if you take out the oem head unit, pretty sure no door chimes.......if that matters.
If I were going to do it today, I would use an ipad or tablet and it would come out similar to the tesla (but I would get around all the interface headaches) way better than what I had and as slick as you want to make it.
Truth be told, for the functions most people want, a replacement double din that goes in the same spot and an off the shelf wiring adapter is way easier and cleaner.
Enjoy whatever you decide
Edit: Can u make the pics smaller?
