Replaced my Key Fobs
Old Jan 5, 2018 | 08:46 PM
AlaJoe's Avatar
AlaJoe
Default Replaced my Key Fobs
Just replaced both my Key Fobs on my 2004. I could kick myself for not doing this a long time ago. I was always afraid the remotes would be expensive because I had 1 and 2 remotes for the memory feature and it is a Vette. I was wrong I got two remotes off of Ebay for $11.95 shipped. I took less than 5 minutes to program them to the car. So if you have a remote that has bad distance or is requiring you to hold down the button harder or longer even after you replaced the battery quit fighting it and spend $11.95 well worth it!
Old Jan 5, 2018 | 09:24 PM
There are some good deals out there on parts for the C5. Sounds like you found a good one.
Old Jan 6, 2018 | 11:00 AM
C5 Kirkland's Avatar
C5 Kirkland
Us 1997-2000 guys are still out of luck.
Old Jan 6, 2018 | 11:12 AM
Heyspike's Avatar
Heyspike
Why is that Kirkland? I need 2 FOB's myself for my 98'.
Old Jan 6, 2018 | 11:53 AM
C5 Kirkland
The is no replacement case available for those years. You have to buy an entire keyfob. Cheapest used I've seen is $80.
Old Jan 6, 2018 | 12:02 PM
pjdbm's Avatar
pjdbm
Yep, huge difference in prices between those years
Old Jan 6, 2018 | 12:12 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Just do this.
Put this on my Y2K. Cost me <$40, huge range improvement.
Old Jan 6, 2018 | 01:32 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
And yet spending thousands on mods is not a problem
Old Jan 6, 2018 | 03:10 PM
wdcraig's Avatar
wdcraig
Default I Was Able to Fix Mine 2X
My car came with both remotes (#s 1 & 2), after putting fresh batteries in them, neither one worked. I took them apart and noticed that both had quite a bit of discoloration on the button contacts on the green "mother board"- and I took a stiff nylon brush and brushed both the open button and close button contacts clean (1st image shows one of the two contacts).
After that both remotes showed signs of wanting to work, but were still not quite right (would lock always, and unlock only sometimes). I then took them apart again and cleaned the rubber button contacts (small black plastic thatched areas using a soft cloth and lighter fluid and the cloth lifted off quite a bit of black grime/residue (2nd image shows one of the two button surfaces).
One of the remotes worked perfectly after cleaning the contact points, but the other one still was not working reliably. I took it apart and noticed that on that remote the solder points (2x) were cracked where they met the battery retaining clip. Using a soldering iron, I reheated the solder and after doing this, that remote has worked perfectly ever since and I use it as my primary, it is #1. (Location of cracked solder noted in the 3rd and 4th images).
Old Jan 7, 2018 | 09:52 AM
02BlownZ06's Avatar
02BlownZ06
I only had 1 key and key fob when I bought my Z06. Added two more fobs and three more keys. The fobs were about $15 each on ebay, same with keys and I had them cut for free:
Old Jan 8, 2018 | 07:25 AM
burneyr's Avatar
burneyr
I did exactly what wdcraig did resoldering the fob - working perfectly ever since!
Old Jan 8, 2018 | 11:19 AM
shot410ga's Avatar
shot410ga
Big price difference between OEM at $98.00 ea. and after market a two for $12.95. Are the aftermarket just as good as the OEM?
Old Jan 8, 2018 | 01:12 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Default Key fobs
I'm thinking the only difference is no GM part number on back...same **** different flies
Like ExxonMobil gas at the ExxonMobil station for $2.89 for premium or same ExxonMobil premium at Walmart gas station for $2.39.
Old Jan 10, 2018 | 12:25 PM
TheProsecutor's Avatar
TheProsecutor
I have no key fobs. I have been using the keys for almost 3 years. Please show me a key fob for a 99 FRC. I can't seem to find any for sale.
Old Jan 10, 2018 | 12:53 PM
02BlownZ06's Avatar
02BlownZ06
They seem to work just as good and look very close to identical. I would not spend the money on the OEM after using the aftermarket versions.
Old Jan 10, 2018 | 06:55 PM
wdcraig's Avatar
wdcraig
Default 1997-2000 Chevrolet Corvette Genuine GM OEM Key FOB Transmitter
Seller shows 10 in stock
https://www.amazon.com/1997-2000-Chevrolet-Corvette-Genuine-Transmitter/dp/B00FM67O06/ref=sr_1_6?ie=UTF8&qid=1515628143&sr=8-6&keywords=1998+corvette+key+fob https://www.amazon.com/1997-2000-Chevrolet-Corvette-Genuine-Transmitter/dp/B00FM67O06/ref=sr_1_6?ie=UTF8&qid=1515628143&sr=8-6&keywords=1998+corvette+key+fob
Old Jan 11, 2018 | 06:17 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if all else fails, just go aftermarket.
I have the avital 2101L system for <$40 with 2 new fobs and much further range than my stock 2000 fobs had.
all you need to do is to piggyback it into your stock wiring and you get back everything you've been missing.
see my video above.
To Replaced my Key Fobs
Old Jan 11, 2018 | 07:12 PM
thefreeauction's Avatar
thefreeauction
see my video above.
JDMVETTE, how hard is this to install? I've installed plenty of car stereos but never anything like this.
Old Jan 11, 2018 | 09:29 PM
jdmvette's Avatar
jdmvette
Night Owl for life
If you've done anything at all with wiring it will be a snap. You just need to know which wires to tap into.
I put the module under the drivers kick panel. Ran wires to the door CM to pop/lock the doors and to disable the factory alarm, ran wires to the BCM to pop the trunk and activate the horn and exterior lights. Ran wires to the ignition for switched power and wired for the interior lights.
It wasn't hard to do at all. I have the wire codes from a fellow forum member and have some wire diagrams for the c5 to tell you which wires to tie into.
Old Jan 11, 2018 | 09:39 PM
jrprich's Avatar
jrprich
https://www.ebay.com/sch/i.html?_fro...y+fob&_sacat=0
