[Z06] Which Roller Rockers
Old Jan 21, 2018 | 11:52 PM
Spaceme1117's Avatar
Spaceme1117
Default Which Roller Rockers
Thinking of getting a set of drop in 1.8 ratio roller rockers. Will be upgrading pushrods and springs at the same time. So which are the best? Harland Sharpe, Comp Gold, Skorpions, or Yella Terra’s?
Old Jan 22, 2018 | 09:05 AM
radar502's Avatar
radar502
Save your money on the rockers ,years back I called Brian Tooley racing ask the same question , He said they at B.Tooley racing had Ls motors making 700+ hp with stock rockers , just install the Trunnion kit . He told me the stock rockers are very light they use them so I did and am very happy ..My 04 makes 550 HP ..
Old Jan 23, 2018 | 12:03 PM
C5SCCA's Avatar
C5SCCA
Engine Masters on youtube has a comparison of rocker arms. They are stud mounted rockers but its worth watching if you are considering swapping yours out.
Old Jan 24, 2018 | 02:11 PM
itsslow98's Avatar
itsslow98
I have yella terra pros ready to go on with my mamo heads/cam/fast build. Lighter than factory and better on valvetrain.
Old Jan 24, 2018 | 02:59 PM
zeevette's Avatar
zeevette
I've had Harland Sharp RR since I installed my TF heads, and they've been fine for almost 10 years. OTOH, I don't race, or even drive that hard, so...
Old Jan 24, 2018 | 03:06 PM
Spaceme1117
Really good episode. They showed a 17 HP increase and 2-3 Lb-Ft tq increase going from 1.5 to 1.6 ratio. That would be about 13 - 14 WHP. Not too bad for not a lot of work.
Seems like either the Harland Sharps or Yella Terra is the way to go. Will upgrade springs to PAC 1219x and get hardened pushrods. May also get titanium retainers to lighten things up.
Old Jan 25, 2018 | 12:40 AM
ASRoff's Avatar
ASRoff
https://www.summitracing.com/parts/jes-kss-318080
My vote goes to this... for a more stable valve train...
To Which Roller Rockers
