Knee Kick panel
Old Feb 7, 2018 | 05:47 PM
chasboy's Avatar
chasboy
Oldtimer
Default Knee Kick panel
I know this seems like a silly question, but has anyone found a way to properly line up the 2 screws for the driver’s side knee kick that mount from underneath. It’s a royal PITA!
Old Feb 7, 2018 | 09:50 PM
I’ll agree that it is a bit challenging to get the screws to line up with the fastener. All I can say is patience pays off.
Old Feb 7, 2018 | 10:14 PM
chasboy's Avatar
chasboy
Oldtimer
Patience! Problem is the fastener moves around! When I was an octopus it would have been no problem. I’m missing at least 6 of my arms and flexibility is a distant memory.
Old Feb 8, 2018 | 03:29 AM
Tsumi's Avatar
Tsumi
The clips the screws go into can slide around. I found the best practice to be get the panel in place, stick screw partially in, pull down panel while feeling for screw and clip, slide the clip until aligned with screw, push up on panel, tighten screw halfway, then do the same for the other screw. In my case, the screw won't back out of the panel easily.
Old Feb 8, 2018 | 06:52 AM
runner140*'s Avatar
runner140*
Difficult answer in three words. Patience, patience and patience. That I have very little of. A little like installing the inside brake booster nuts.
Old Feb 8, 2018 | 09:16 AM
chasboy's Avatar
chasboy
Oldtimer
Thanks guys. I’ve tried using a scratch awl to line it up but the awkward position usually results in a slip or dropping of something . I used a mirror and 2 bought for this purpose led droplight style flashlights so I can see. Still could use a few more hands tho’.
Old Feb 8, 2018 | 12:00 PM
corvettebob1's Avatar
corvettebob1
Pay the kid next door a few bucks to do it, he'll get it done in less time then it takes you to get down there.
Old Feb 8, 2018 | 12:28 PM
chasboy's Avatar
chasboy
Oldtimer
Old Feb 9, 2018 | 06:43 AM
3sACROWD's Avatar
3sACROWD
It may seem excessive but you could always take the seat out to give yourself more room. Remove 4 nuts and an electrical connector and your seat is ready for removal.
Old Feb 9, 2018 | 08:13 AM
chasboy's Avatar
chasboy
Oldtimer
Wish I thought of that sooner! Since I just replaced all the rugs, and reinstalled the seat, I’ll just suck it up (in?) and get’er Done.
To Knee Kick panel
