Time to trash the Blose system..
#41
I am awaiting my Vettenuts bezel but wondering how to determine how deep to mount the head unit. I know I can slide it in loose, trial fit the bezel until it fits, then try to remove the bezel without disturbing the head unit. But if there is a better way I would like to hear about it. I have had C5 bezels off many times over the years but never had to determine just how deep to place the HU in the framework.
Jim
Jim
The Lizzard
jrprich (02-19-2018)
#42
I attached my mini-amp following the method used by Patches in his post on this topic:
https://www.corvetteforum.com/forums...-overhaul.html
I believe Patches placed his cross-overs by the amp for ease of tuning. I didn't do that, but instead placed mine under the dash. I can still get to them and tune the system should I ever want to (although the cross-overs are passive devices and, once tuned, should not likely require subsequent tweeking.)
I bought and installed a Kenwood XR900 900 watt, 5 channel mini-amp...very light weight. [More technologically advanced mini-amps can be had now...I bought mine in April 2013.] I fabricated a cover for the mini-amp - mainly to hide the power cable and all of the speaker wiring - using a counter top dish drain pad I bought from Walmart (black to match the carpet). I cut a square opening just larger than the amp (for cooling purposes) and then stitched piping around the edges of the cut to hide the messy frayed materials. The mini-amp hasn't once overheated so I guess my "fix" was adequate.
The Lizzard
OleStraightStick (02-20-2018)
#43
I wanna thank everybody for the awesome responses.. so far I’ve been working on disassembly.. got the console, bezel, h/u, hvac, door sill panels, and all the carpet and panels removed from aft of the seats.. gonna pull the door panels next
#44
i was also considering one of those Kenwood 5 channel excelon amps, so small and light plus tons of power.
#45
Just been working on it here and there when I get the time.. got most of what I plan on insulating with the butyl completed.. that stuff sure does stick good.. once ya peel the paper backing off it’s like a tar adhesive lol
red03vette (02-24-2018)
#46
Hes a write up i did when i did mine. I went with ensolite and raamat from ram.audio. i have to say my system sounds fantastic. And its very docile in the cockpit.
Hope this helps
https://www.corvetteforum.com/forums...o-upgrade.html
Hope this helps
OleStraightStick (02-24-2018)
#47
Ok so I have another question.. I’m in the process of re-wiring and can’t seem to find many good detailed instructions online on how to tap into the accessory & reverse wires, etc.. all the write-ups seem to rush past that portion of the install (or have in-accessible photobucket pics included).. do I need a separate gm harness to connect to an aftermarket receiver even if I’m signaling all the speakers through RCA’s? Isn’t there a dimmer connection that needs to be made? Might be some silly questions but I definitely appreciate everyone’s input!
#48
OleStraightStick (02-28-2018)
#49
In the passenger side footwell to the left of the, forgot what that box is called, electrical box in footwell, there are three wires taped together that don’t go to anything. One is always hot, one is on with the key, and one is ground. I also ran an extra wire to the rear of the car and spliced into the backup light for the reverse wire. I have my HU in place and all wired, waiting for the bezel to do the final fitment.
#50
or
#51
Thanks y’all.. jrprich, those harnesses are for connecting an aftermarket stereo with the factory Bose speakers.. I’m re-wiring everything so those won’t work..
So I reckon I won’t need any harness at all? I need’a get the new h/u out and see what it comes with & how the inputs/outputs are the rear are configured.. I just know for sure it has 3 rca channel outputs
#52
#53
That’s what I was thinkin’.. do you by any chance have a link to one? Once again, I really appreciate it
#54
I don't, none of them had the corvette listed as compatible so I went to Best Buy and bought all the ones they had and can't remember what I used before I took the rest back.
#55
Lol well crap, the closest Best-Buy is in another city, about 45 mins away.. hopefully somebody can chime in with an Amazon link or a part number so I can order one
#58
Looks great!
You noted the use of the butyle rope. I just wanted to mention for anoyone's future reference- a product called Mortite works well also. It's a window/door sealant you can find at a hardware store. It's light gray, comes in a roll, and individual strands can be pulled off. It has the consistency a little less stiff than modeling clay. Easy to form and not messy at all.
I used a bead of that between every metal/plastic/speaker surface I could.
OleStraightStick (03-19-2018)
#59
I went against my original idea and also decided to dump the whole Bose system. I went with a new Kenwood headunit, a Memphis Mono D block sub amp, a Kicker 4ch amp, infinity 2 way 6.5 door speakers and a Skar 12" sub. I won't be running the rear 5.25" speakers.
