Weather strip question
Old Feb 21, 2018 | 03:27 PM
1997 C5's Avatar
1997 C5
Default Weather strip question
My C5 weather strips especially top of the roof rear of Targa top is dry rotting. Can anyone recommend a weather strip revitalizer that put the moisture back into rubber seals to make
it last longer and protects it from environment?
Old Feb 21, 2018 | 03:45 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
I was told to wipe the rubber with baby oil.
Old Feb 21, 2018 | 04:11 PM
SG Lou's Avatar
SG Lou
Once that cast foam latex weatherstripping starts to break down and deteriorate about the only thing to do is replace it. I know it's expensive but there is no other choice ............IMO anyway .
Old Feb 21, 2018 | 06:22 PM
Joe Scafide's Avatar
Joe Scafide
I use electrical dilation grease
Old Feb 21, 2018 | 07:02 PM
Corvette#2's Avatar
Corvette#2
I used dielectric grease on all my weatherstripping. I used some generic stuff from an auto parts store, but I think it's basically the same stuff in the actual GM brand weatherstripping lube, dielectric grease.
Old Feb 21, 2018 | 10:43 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
its not really expensive to replace and pretty easy to do as well
Old Feb 21, 2018 | 10:46 PM
steve8's Avatar
steve8
Another vote on dielectric grease.
Old Feb 21, 2018 | 11:12 PM
Years ago I contacted a local body shop about what product they would recommend to keep the weatherstripping in good, pliable shape. They recommended some natural silicone lubricant. Bought a can of it and it works very well in treating the weatherstripping. Just another alternative to consider.
Old Feb 22, 2018 | 12:25 PM
rrwirsi's Avatar
rrwirsi
I also use electrical dilation grease every other year since I am not sure which one protects the best.
Old Feb 22, 2018 | 05:23 PM
1997 C5's Avatar
1997 C5
The OEM weather strip to roof @ rear of Targa top is very expensive> I know you can get after market for around $160.00 but I don't know how well a/m weather strip is to oem far as fit
and sealing the targa top. I notice a/m weather strip has no sealant tape on like oem weather strip at certain spots. Have you replace one on your car?
Old Feb 22, 2018 | 06:47 PM
WetMountainMan's Avatar
WetMountainMan
What is the procedure for using dielectric grease on the rubber seals? It seems like it would be very messy.
Old Feb 22, 2018 | 06:51 PM
SG Lou's Avatar
SG Lou
Wipe on, rub into W/S, wipe off excess
Old Feb 22, 2018 | 07:00 PM
SG Lou's Avatar
SG Lou
I paid some where in the neighborhood of $300 for a factory NOS-OEM B pillar W/S for mine. Got it off of eBay
From what i have read, most of those aftermarket W/S are joined together at the corners with 45 degree glue joints verses the OEM which is injection molded as one piece.
Old Feb 23, 2018 | 04:14 PM
glbeauchamp's Avatar
glbeauchamp
Silicone grease, like Syl Glide from NAPA.
Old Feb 23, 2018 | 05:56 PM
ant-knee470's Avatar
ant-knee470
Weather stripping is expensive..
I have a convertible 98 c5 and the 6 little 8-10" pieces I need are over $600.00.. I think it's in the expensive ball park.. I am gonna have to do it soon tho, along with a new top..
Old Feb 23, 2018 | 06:03 PM
Corvette#2's Avatar
Corvette#2
It is messy. I used rubber gloves. Applied the grease to my fingers and then rub it onto the weatherstripping. Wiped off excess with a microfiber towel.
The next day I could see greasy areas on my door cards and other places it shouldn't be. But it cleaned up easy with isopropyl alcohol.
To Weather strip question
