Skip shift install?
Old Mar 1, 2018 | 12:08 AM
Ducati Guy's Avatar
Ducati Guy
Default Skip shift install?
Getting ready for spring here sooner than later in the north east. Want to install Compliance Parts skip shift eliminator. How easy is that task? Anyone care to give me a general over view of the install?
Old Mar 1, 2018 | 02:16 AM
o2bnkc's Avatar
o2bnkc
I did mine years ago, but as I remember it only took a couple of minutes. It took longer to jack up the car than install the part!
Old Mar 1, 2018 | 03:41 AM
jasper1978's Avatar
jasper1978
How can I check if my car already have a skip shift module installed??
I have never seen the skip shift warning come on whilst driving.
Old Mar 1, 2018 | 08:35 AM
In your owners manual it states under what conditions the CAGS (Computer Aided Gear Selection) feature kicks in. If you drive under those conditions and do not have the skip shift eliminator installed, you will definitely notice when CAGS takes over since you will only be able to shift 1-4 instead of 1-2. If you do have the eliminator installed, you will be able to do a 1-2 shift under all driving conditions.
And to the OP, the skip shift eliminator is very easy to install. The directions that come with it are clear and as long as you can get the car up in the air a bit (floor jack works fine), the job should only take a few minutes. Just be sure to zip tie the disconnected wire up out of the way to keep it off hot components.
Old Mar 1, 2018 | 08:57 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I always get confused when I see this question asked. It appears there are two different companies that make a shift eliminator.
I know I bought mine from Richard at Compliance and I do not recall jacking the car to install it. IIRC it was all done in the battery area.
From the Compliance website:
The CAGS-SKIP makes 3 connections to your Corvette:
1.) A fused connection to the positive post on the underhood fuse panel.
2.) A terminal that replaces an OEM terminal in a connector that disables the skip-shift solenoid.
3.)A CAGS-SKIP wire spliced to a wire located beneath the underhood fuse panel.
The CAGS-SKIP installation DOES NOT require raising your Corvette and crawling underneath to access the connector on the transmission!
The CAGS-SKIP is easily installed under the hood, next to the battery.
Old Mar 1, 2018 | 09:54 AM
98C5P's Avatar
98C5P
http://www.westcoastcorvette.com/p-4...1997-2013.aspx
This is the one that is on mine.
Old Mar 1, 2018 | 10:03 AM
digitaloutsider's Avatar
digitaloutsider
Deleting it out of the PCM is by far the best way. No stupid light, no wire splicing, no nothing. Like it was never even there!
Old Mar 1, 2018 | 10:10 AM
motorboater222's Avatar
motorboater222
I installed mine in 10 minutes on my lowered C5 without having to jack it up. Just come in from the rear exhaust you can see it plain as day. What a stupid option from GM.
Old Mar 1, 2018 | 10:26 AM
grampi50's Avatar
grampi50
Is there a procedure somewhere for doing it this way?
Old Mar 1, 2018 | 10:27 AM
grampi50's Avatar
grampi50
Could be the worst one they ever did...
Old Mar 1, 2018 | 11:36 AM
Moto One's Avatar
Moto One
Just warm up the locking clips (if your in a cold climate ) at this age they are brittle when cold.
Mark.
Old Mar 1, 2018 | 11:45 AM
glbeauchamp's Avatar
glbeauchamp
At the time, the GM engineers, under a stringent timeline, were desperately trying to wring every .1 mpg increase to pass CAFE standards. They figured a few less rpms here and there might push it over the top. They did what they had to do. It least it's an easy fix. I used the one that plugs into the transmission. As o2bnkc says, it takes almost as long to jack the car up as it does to install the part. Only thing is the dashboard light still comes on reminding you when to shift.
Old Mar 1, 2018 | 02:13 PM
3sACROWD's Avatar
3sACROWD
Yep! They avoided the government's gas guzzler tax on the Corvette by doing that.
Old Mar 1, 2018 | 02:25 PM
o2bnkc's Avatar
o2bnkc
You must have a different kind of gizmo than mine. As I remember, I think I just plugged it in the side of the transmission. Nothing else.
Old Mar 1, 2018 | 02:44 PM
grampi50's Avatar
grampi50
That's the one I'm thinking of too, just plugs into the existing connectors on the tranny...
Old Mar 7, 2018 | 10:30 PM
WRTHW8's Avatar
WRTHW8
I did mine with my car in the air. Took less than 5 minutes including me zip tying it up. That was the first mod I did.
Old Mar 8, 2018 | 01:50 AM
observer2017's Avatar
observer2017
Follow this URL
http://www.complianceparts.com/c5cags-skip.html
To Skip shift install?
Old Mar 8, 2018 | 09:38 AM
jjc508520's Avatar
jjc508520
I went to Radio Shack (when they were open) and got a 20-ohm resistor and shoved in in the socket - total cost about $0.20. Did the same on my '95 Z-28...
Old Jul 14, 2025 | 07:02 AM
frankdubbs's Avatar
frankdubbs
I got my 14’ M7 with 14k miles delivered by Carvana. They had a 7 day 400 mile return period. Best way I thought to check the car out (to make sure she was good to keep ) was immediately get it in the air and change all the fluids and inspect what I could. The CAGS eliminator was $18 so I popped it in while I was down there.
Sure you can drive around the skip shift but why bother if it’s easy enough to disable. For me it often kicked in when I needed 2nd gear the most, usually in larger intersections where I was making and left with oncoming traffic and I wanted to be in second to scoot and not fourth.
IMHO This And the MGW shifter should be first mods everyone does. Even if you are hard set on keeping your car stock, these are quality of life items that can be removed easily if needed.
Old Jul 14, 2025 | 09:22 AM
Dads2kconvertible's Avatar
Dads2kconvertible
Originally Posted by frankdubbs
my 14’ M7
That's probably great information for C7 owners. The C5 thread you replied to is several years old.
