Halo led tailights hyperflash question. Help please
Old Mar 5, 2018 | 04:44 PM
OUTAKTRL's Avatar
OUTAKTRL
Default Halo led tailights hyperflash question. Help please
What's up guys. Strange thing happened today. I've had led halo mod tailights for almost a year now. Worked fine from day one. No hyperflash harness needed. I haven't installed any other led lights since. Today when I put on only the left turn signal I get hyperflash. I knocked the housing a bit and it seemed to return to normal flashing. But then started hyperflashing again. Hazards flash normal. Only left turn signals hyperflash. Front 3157 bulb seems ok. Might be loose or need replacing. Couldn't check today. I'll check tomorrow. But does anyone know why out of the blue this happened ? Any help will be greatly appreciated.
Old Mar 5, 2018 | 04:56 PM
deejbee's Avatar
deejbee
Can't say for sure, but similar happened to my car. I wrote it off as one of the resistors (or some electrical doo-dad) in the taillight going bad, thus triggering a hyperflash.
I think some halo lights came with electronics to eliminate hyperflashing so they could be "plug and play".
I had to get a hyperflash harness and no issues at all since.
Old Mar 5, 2018 | 05:28 PM
OUTAKTRL's Avatar
OUTAKTRL
I believe mine have the built in resistors. They never hyperflashed before. Had em half a year.
Old Mar 5, 2018 | 05:34 PM
OUTAKTRL's Avatar
OUTAKTRL
Djb. Do u need just one hyperflash harness ? Thx
Old Mar 5, 2018 | 07:24 PM
Crosis's Avatar
Crosis
yes. just one
Old Mar 5, 2018 | 08:46 PM
Try swapping the right taillights for the left and see if they still hyperflash. You do not need to install them fully - just plug in the light to the harness.
Old Mar 5, 2018 | 10:33 PM
dbgoodwin's Avatar
dbgoodwin
Before I installed my hyper flash relay I had that happen once. It was literally a matter of ensuring the connections were secure for me. I noticed that on the hyperflash side, one of the two turn signals wasn't actually working.
Get the relay, it solves the problem entirely and you can throw in some LED switchbacks up front after, with no hyperflash.
Old Mar 5, 2018 | 11:15 PM
luffy's Avatar
luffy
I just had the exact same issue with my LED Halo tails. Only on left turns, I would get occasional hyperflash. For me, it actually seemed to be related to ambient temps so i'm thinking the heatsink / resistor on one of the tail lights was failing. I didn't want to spend the money / time to get a harness, so I installed a generic set of chinese LED resistors, this fixed the problem completely. I actually just zip tied the new load resistors to the heatsink on the back of the tail light. Not the most elegant solution, but it cost $8 rather than 10x for a hyper flash harness.
Old Mar 6, 2018 | 09:38 AM
jjc508520's Avatar
jjc508520
Possible bad ground...
Old Mar 7, 2018 | 02:32 PM
MAJ_Charlie's Avatar
MAJ_Charlie
I had the same problem years ago...went to the LED lights and halo tail lights...worked great for a while...then just like you...no warning...hyperflash. Got the hyperflash harness which also allowed me to run LEDs up front without the PITA of doing resistors and splicing....no issues in over 4 years.
Old Mar 7, 2018 | 02:35 PM
Tsumi's Avatar
Tsumi
A hyperflash harness is less than $40, not $80, solves the issue of a bad hazard switch, which is about $35, and allows you to run LEDs in the front instead of halogens, which tend to crack the housing at a cost of $50-80.
Old Mar 7, 2018 | 05:39 PM
87convpaul's Avatar
87convpaul
Likely a loose wire connection with your wire splice connectrs
Old Mar 7, 2018 | 07:47 PM
dbgoodwin's Avatar
dbgoodwin
the thing about the hyperflash relay for $40 is that it also eliminates the problematic hazard switch.
Old Mar 7, 2018 | 08:41 PM
twill's Avatar
twill
Default Same here!!!
I had the resistors and they were fine for about a year. Then out of the blue I started to get the hyperflash. I took off the resistors and put on the harnesses and all is GREAT,
Old Mar 7, 2018 | 11:53 PM
luffy's Avatar
luffy
good point, I'm in Canada, and by the time they get to my door, I was finding them $80-100 cdn, I should have clarified. If you can share a link to a harness for $30, I'll pick one up.
Afan
Old Mar 8, 2018 | 09:42 AM
jjc508520's Avatar
jjc508520
I fact this is what I believe my "bad ground" issue was...
To Halo led tailights hyperflash question. Help please
