Yellow-Off-Yellow-Off LED Switchbacks
Old Mar 7, 2018 | 04:51 PM
grassblaster's Avatar
grassblaster
Originally Posted by Tsumi
Hyperflash harness. It goes in between the hazard switch and the turn signal stalk, and redirects the flasher signal to an LED flasher.
Yes, running lights. Running lights and parking lights are used interchangeably. Running lights is the American term, parking lights is the European term. The amber requirement I believe is for the front side-facing lights, not the front-facing lights. Front-facing can be white or amber.
Indeed there are. In the clear section, there is a 3157 bulb that does running/turn signal duties. In the reflector section towards the rear, there is a 194 bulb that does running light duty only.
I'm starting to track. So i need a harness or 2? any links for those?
Old Mar 7, 2018 | 04:55 PM
Tsumi's Avatar
Tsumi
Only one harness needed. It installs right in the dash, look up a video or two. It's very easy to do.
https://www.amazon.com/Corvette-Envy-Signal-Bypass-Harness/dp/B014ZOU9E8/ref=sr_1_2?ie=UTF8&qid=1520459602&sr=8-2&keywords=c5+hyperflash+harness https://www.amazon.com/Corvette-Envy-Signal-Bypass-Harness/dp/B014ZOU9E8/ref=sr_1_2?ie=UTF8&qid=1520459602&sr=8-2&keywords=c5+hyperflash+harness
-$45 on Amazon
https://www.ebay.com/p/C5-Corvette-L...EDs/1047394236 -$40 on Ebay
Old Mar 7, 2018 | 05:07 PM
grassblaster
https://www.amazon.com/Corvette-Envy...rflash+harness -$45 on Amazon
easy enough
