Help me remove rear bumper inserts
Old Mar 9, 2018 | 07:36 PM
FYRARMS's Avatar
FYRARMS
Default Help me remove rear bumper inserts
My car's previous owner installed these tacky polished stainless steel (I assume they are) bumper inserts, and they look like garbage. I refuse to drive a car that looks like it crashed into the cheap chrome garbage aisle at Vato Zone.
My previous C5Z had black vinyl inserts that I was able to peel off easily. These stainless ones look a little trickier. Obviously, I want to remove these turds without scratching the finish. What do you guys think? Hair dryer or heat gun? Maybe dribble some Goo-Gone behind each letter? Anyone tackle this before?
Old Mar 9, 2018 | 07:50 PM
Use a hair dryer to soften the double sided tape and then use either a thin, hard plastic pry tool or a thin flat blade screwdriver to gently lift the letters off. A little WD-40 or the Goo Gone might help too.
Old Mar 9, 2018 | 07:53 PM
FYRARMS's Avatar
FYRARMS
My thoughts as well, unless someone has a better idea. I appreciate the reply!
Old Mar 9, 2018 | 08:03 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...they do look like total Chitt....just heat enough without melting the bumper and pull...heat and pull...heat and pull...if you heat then pry with your finger nails they will probably just lift off easily then you can use a little WD 40 to get the sticky off...
btw...it will be easier than removing BSMs...that would be your next step incase you even have them...
Old Mar 9, 2018 | 08:31 PM
FYRARMS's Avatar
FYRARMS
Helllll no. In fact, I am actually removing the OEM Z06 fender emblems and OEM 2003 front and rear crossed flag emblems. The front nose crossed flag is being replaced with a black pre-'03 emblem with carbon fiber inserts.
Old Mar 9, 2018 | 10:07 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Old Mar 10, 2018 | 08:26 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Soften the glue as mentioned above and use a piece of fine monofilament to “saw” and pull through the glue. You won’t touch the paint at all.
Old Mar 10, 2018 | 09:53 AM
Moto One's Avatar
Moto One
What he said above.
Mark
Old Mar 10, 2018 | 11:59 AM
FYRARMS's Avatar
FYRARMS
Thanks, guys. It will be tough to get fishing line in there, as these letters are pretty flush with the body. Hopefully, once heated up, I can gently pull the letters out a bit to thread in some line.
Old Mar 10, 2018 | 12:50 PM
c5vetteguy's Avatar
c5vetteguy
If you use something like a 20lb. test (fine) monofilament, it’ll be thin enough to get between the letters and bumper. If you can snake a loop around just one corner of a letter, you’ll be home free.
Good luck!
Old Mar 12, 2018 | 08:59 AM
Velocity_Vette's Avatar
Velocity_Vette
Once you remove them with heat - which is what I would do - do not be afraid to liberally spray WD-40 on the inserts to remove the residue like Vettman Jack recommended; I'd recommend it over Goo Gone. WD-40 does a pretty good job of penetrating any sticky residue on paint, and it will not damage anything. I would spray each one, let it sit for five minutes, and then with a spare shammy scrub at it. Finish up with your typical detail work.
WD does a pretty good job at removing surface scratches also. I had a tire carcass hit the front of my car and WD removed all the black marks. Sans a few clear coat scratches it looks like nothing ever happened.
Old Mar 12, 2018 | 12:18 PM
FYRARMS's Avatar
FYRARMS
I have both WD-40 and Goo Gone in my arsenal. Also, per the detailing forum I belong to, everyone suggested using "Rapid Remover", which they claim is the best of the best. Ordered a small bottle from Amazon. Going to tackle this job next weekend when it warms up in Chicagoland. I will keep you guys posted and take pics of the surgery! LOL
To Help me remove rear bumper inserts
