Did You Know.....
Old Mar 16, 2018 | 11:51 PM
LannyL81's Avatar
LannyL81
Default Did You Know.....
....that if you leave the headlight connectors un-mated that the "key is in the ignition" chime comes on when driver's door is opened...??
I recently had to replace the headlight gear in the left side headlight lift motor...(quite easy to do by the way). After re-stalling the headlight assembly back in the car, I left the connector un-mated as I was going to go ahead and do the right side....which I did a few days later.
I also left the right headlight connector un-mated. I then needed to drive the Corvette, (was in the daytime) shut the hood and took off. Got to first stop, got out...ding, ding, ding, ding......with keys in my hand. What is that all about....has the ignition key failed on me??
Left there and went to second stop, got out....ding, ding, ding, ding....with keys in hand....really, now I have to pull the ignition switch out.....then I remembered that I never made those connections.
Made the connections, started engine, both lights open (I did not touch the headlight control)...then close. Shut off engine, opened driver's door and no more ding, ding, ding.
Guess the car was telling me that I really, really need to plug those headlights in.
So now you know....."the rest of the story."
Old Mar 17, 2018 | 12:43 AM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
C5- the original “smart car”
Old Mar 17, 2018 | 07:37 AM
02BlownZ06's Avatar
02BlownZ06
There are a lot of things it does you never know if you didn't read about it. I believe there is sticky on here about all the things you can do like shake the car to unlock it somehow if you lock your keys in.
Old Mar 17, 2018 | 11:17 AM
Interesting and good thing you ended up thinking about the connectors and the chimes - saved a lot of troubleshooting.
Old Mar 17, 2018 | 05:09 PM
o2bnkc's Avatar
o2bnkc
That actually works if you have the older passive system.
Old Mar 19, 2018 | 10:22 PM
John1990's Avatar
John1990
Originally Posted by LannyL81
....that if you leave the headlight connectors un-mated that the ........................................ ...........
Good day.
To Did You Know.....
