Tire gauges won't reset
Old Mar 26, 2018 | 05:26 PM
Adavis's Avatar
Adavis
Default Tire gauges won't reset
Ok guys here's the deal, I had my rear tires changed in my 01 corvette and the sensor popped up. I tried to reset the tires but it will not reset the back tires. What do I do? Is there a part I need to buy or is there any easy fix?
Old Mar 26, 2018 | 05:32 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Try this...
Old Mar 26, 2018 | 05:42 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
did you drive the car??
Old Mar 26, 2018 | 06:12 PM
Adavis's Avatar
Adavis
yes I drove the car and there was no change. Thanks for the video unfortunately that is what we did.
Old Mar 26, 2018 | 06:17 PM
Adavis's Avatar
Adavis
We did exactly what the video said to and it just will not reset. Front tires are cleared. The back tires are what we had changed and that is where the problem lies. Drive the car and everything remained the same.
Old Mar 26, 2018 | 06:19 PM
JR-01's Avatar
JR-01
Did you use a strong magnet?
Old Mar 26, 2018 | 06:21 PM
Adavis's Avatar
Adavis
Yes. Horn beeped and the hole nine yards.
Old Mar 26, 2018 | 06:23 PM
JR-01's Avatar
JR-01
The horn beeped on all four sensors? If so you have to drive it for awhile to get correct reading.
Resetting the C5 Tire Pressure Monitoring System
Keyed from the Service Manual by Registry Member: Randall H. Shinn
TPM Sensor Programming
The Tire Pressure Monitor (TPM) system interfaces with the Instrument Panel Cluster (IPC) through the serial data line. Once the program mode is accessed through the IPC, each sensors unique identification code can be programmed into the receiver's memory.
Each sensor must transmit the unique code in the proper sequence. A magnet must be held close to the sensor in order to force the sensor to transmit the identification code. The IPC will display a message as each sensor is programmed, and when to proceed to the next sensor for programming. The receiver also sends a message to the BCM to sound the horn one time, indicating that the sensor properly transmitted an identification code. If the programming sequence is cancelled before any sensor is programmed, or if the vehicle's battery is disconnected, the receiver will remember all current identification codes. As soon as the receiver learns the first sensor code, all previously stored codes are erased from the receivers memory.
Programming TPM Sensors
Tool Required
Tire Pressure Monitor (TPM) System Programming Tool Tire Pressure Monitor (TPM) System Programmer
(TPM System Programming Tool means "magnet" to ordinary C5 owners!)
Important: Make sure the vehicle has been stationary for at least 2 minutes before attempting to program the TPM sensors.
1. Turn the ignition to ON.
2. Press the RESET button in order to clear any IPC display warning messages.
3. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
4. Press and hold the DIC RESET button for 3 seconds.
5. Press the OPTIONS button again until the TIRE TRAINING message appears.
Notice: If the TIRE TRAINING message cannot be displayed, and the IPC is functioning properly, check if the BCM is configured with the correct RPO codes. Refer to BCM Programming/RPO configuration.
6. Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
7. Install the J 41760 Tire Pressure Monitor (TPM) System Programming Tool over the left front valve stem.
8. The horn will sound, indicating the left front TPM sensor is programmed.
Important: If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool. This procedure may have to be attempted up to three times in some instances.
When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages
- LEARN R FRONT TIRE
- LEARN R REAR TIRE
- LEARN L REAR TIRE
Programming Cancellation
1. The programming mode will be cancelled if any of the following conditions are met
- The program mode is exited through the DIC.
- The ignition is turned to OFF.
- All four sensors have been programmed.
- The TPM system has been in the program mode for longer than 2 minutes and no sensors have been learned.
2. If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
Old Mar 26, 2018 | 06:24 PM
pewter99's Avatar
pewter99
well hell.....give it a few days.....drive it......
alternatively.....disconnect battery for 30 min and then reconnect see what happens.....believe it or not that fixes a lot of stuff with the C5
Old Mar 26, 2018 | 06:30 PM
Adavis's Avatar
Adavis
Okie dokie. I will try that. I don't think the horned beeped four times. Idk my husband did it and he said it didn't work so here I am trying to figure out what yal think. I know it beeped 3 times because I thought he was trying to get my attention. It would not reset the back tires. Would it make a difference if we switched the tires around? Is it possible they put the tires on the wrong side? I have no idea about cars. Should I buy new sensors? Should I wait it out? Disconnect that battery is the next step? Thanks for all the help.
Old Mar 26, 2018 | 06:33 PM
Adavis's Avatar
Adavis
Ok so it got stuck on the right rear tire. Would not reset it and therefore could not go any further. Magnet worked fine it just won't reset pass the right rear tire
Old Mar 26, 2018 | 06:36 PM
JR-01's Avatar
JR-01
Before you order new sensors. Take your time and follow the above instructions exactly. If you get them all to beep. Go drive the car and see if they work. If one will not train after a few tries you may need a new sensor.
Old Mar 26, 2018 | 06:44 PM
Adavis's Avatar
Adavis
Ok thanks
Old Mar 26, 2018 | 09:11 PM
If it doesn't work, it could be that when the shop installed the new tire(s) the sensor was damaged. If so, a new sensor would be in order.
Old Mar 26, 2018 | 09:37 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I just did a friends (C5) car using old speaker magnet.
The first time we did it, drove the car and it didn't reset itself in 20 miles, so we did it again, and bam all systems working second time.
Old Mar 26, 2018 | 10:24 PM
pewter99's Avatar
pewter99
FWIW my 07Z took 2 days to come online
Old Mar 27, 2018 | 07:39 PM
ctomlin@amroc.us's Avatar
ctomlin@amroc.us
Had the same problem After several days the rear tires reset. There was actually no reading for the rear tires for a couple of days.
To Tire gauges won't reset
