Keeping exhaust stright
Old Apr 4, 2018 | 10:39 AM
slvr bulit's Avatar
slvr bulit
Default Keeping exhaust stright
I have had my corsa axle back exhaust on for over 10 years but lately I am having a hard time keeping the tips straight. Has anyone replace the clamps and what are you using. Or what are your suggestions to keeping the tips straight? Tack welding?
Old Apr 4, 2018 | 10:54 AM
rrichar2591's Avatar
rrichar2591
I had the same problem with my Corsa Tigersharks right after they were installed. The shop suggested tack welding and that solved the problem. Been over a year now and they are still perfectly aligned.
Old Apr 4, 2018 | 10:57 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
band clamps !!!!
Old Apr 4, 2018 | 11:57 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Mine got all wonky so I spent a good afternoon learning which push, twist, pull did what. After that I tightened the snot out of the clamps.
It is now part of the spring maintenance like Techron and an oil change.
Good Luck!!
Old Apr 4, 2018 | 12:03 PM
Quickshift_C5's Avatar
Quickshift_C5
Get a board long enough to go under both tips. Prop them up with the board securely, then tighten the clamps.
When I pulled everything apart to replace my clutch, I put the last part of the exhaust on lying on my back with the car on jack stands. I had the clamps just loose enough to move them around. I laid a board on my knees and brought it up to the tips and forced them up even and tightened them up and they came out perfectly level on the first try.
Old Apr 4, 2018 | 02:17 PM
slvr bulit's Avatar
slvr bulit
When I did my clutch a few years ago I added LG longtubes and when I put my corsa back on it was all good now a few years later I cant keep one side tight. Going to try the band clamp like Ponder suggested first then the welding.
Old Apr 5, 2018 | 11:10 AM
6speedsteve's Avatar
6speedsteve
Don't forget to torque them properly, it does help.
Some reference info, not saying Magnaflow is better than others.
https://www.magnaflow.com/support/te...proper-torque/
http://www.jegs.com/p/Magnaflow/Magn...67935/10002/-1
Old Apr 5, 2018 | 11:14 AM
6speedsteve
http://www.normaamericasds.com/brand/torca
Old Apr 6, 2018 | 07:54 AM
grampi50's Avatar
grampi50
When you guys tack weld them, what are you welding them to?
Old Apr 6, 2018 | 08:16 AM
runner140*'s Avatar
runner140*
Pounder strikes again....band clamps. I'm still using a several of his suggestions.
To Keeping exhaust stright
