2001 c5 6 speed shifter
Old Apr 16, 2018 | 04:13 PM
Boohooshotrod2001's Avatar
Boohooshotrod2001
1st Gear
Default 2001 c5 6 speed shifter
which is the best replacement shifter for c5 2001 6 speed, a Hinson, Hurst or B & M? I want it for accuracy & not for speed!
Old Apr 16, 2018 | 04:30 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the ONLY ONE with the lower box, which is EVERYTHING !!!MGW !!!!!!
Old Apr 16, 2018 | 04:58 PM
grantv's Avatar
grantv
C6 Z06 full shifter also...
Old Apr 16, 2018 | 05:52 PM
The MGW or the C6 Z06 shifters are very popular. Can’t go wrong with either one.
Old Apr 16, 2018 | 06:12 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the C 6 still uses a crappy lower box !!!!
Old Apr 16, 2018 | 08:55 PM
PeterC3's Avatar
PeterC3
I just purchased a C6 shifter from a forum member for my '01 Z06 to try out on the track. I'm a nube, explain the lower box?
The tranny in my 'vette I suspect is tired and needs overhauling. Reverse is often a bear to get to, except when driving - trying to get to 5th gear...
Why is the shifter upgrade so significant? What should I expect?
Old Apr 16, 2018 | 11:30 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the stock box has very weak bushings and are prone to wear out, the lower box for the MGW is state of the art with extremely good bushings and the box is machined out of aircraft quality aluminum. Any movement in the shift linkage will effect the trans going into desired gear. pic of MGW (it is a work of art) !!!!
Old Apr 16, 2018 | 11:58 PM
NCVette1's Avatar
NCVette1
I went from a C6Z06 to MGW. Can confirm MGW is awesome.
Old Apr 17, 2018 | 09:25 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I guess you don't know about this option yet. A vendor here completely upgrades your lower box for $125 shipped with needle bearings and a CNC'd cap. Great option especially if you already have an aftermarket shifter like I do.
https://www.corvetteforum.com/forums...ter-boxes.html
Old Apr 17, 2018 | 09:41 AM
DetroitPlac's Avatar
DetroitPlac
Just had Todd rebuild my lower box. The thing is a work of art, and significantly tighter than it was when I sent it to him. Weather is still garbage in Michigan, but driving impressions should be coming next week.
I think a lot of people overlook the lower box (partially due to lack of rebuild options) and just replace the shifter and end up with mediocre results. I'm starting with the bottom box and my stock shifter and going from there. My stock shifter has zero play in it, so I know it's not contributing to inaccuracy (longer throws, though).
Old Apr 17, 2018 | 10:16 AM
jjc508520's Avatar
jjc508520
Which of these will work with the stock shifter ****?
Old Apr 17, 2018 | 11:48 AM
digi2t's Avatar
digi2t
Looks just as good on the mantle.
MGW provides the proper C5 thread with the shifter. Choose 9/16 - 18 at time of purchase.
Old Apr 17, 2018 | 05:37 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
[QUOTE=~Josh;1597015054]I guess you don't know about this option yet. A vendor here completely upgrades your lower box for $125 shipped with needle bearings and a CNC'd cap. Great option especially if you already have an aftermarket shifter like I do.
nice option but, 125 plus what you pay for a different shifter, most likely more than the MGW ??? Hinsen is like 410 dollars ???
Old Apr 17, 2018 | 06:13 PM
knewblewkorvette's Avatar
knewblewkorvette
Had stock shifter in my 02, liked it.
Had a B&M ripper shifter in my 98, hated it.
Put in a C6 Z06 shifter in my 98, liked it.
Have a B&M shifter in my 99, like it.
Put a MGW shifter with a innovativcar-tech.de **** in my 02, love it.
Old Apr 17, 2018 | 07:59 PM
NCVette1's Avatar
NCVette1
If anyone has experienced Barton shifters in other cars I just wanted to tell you guys that MGW is the only company that is comparable. Not sure I would put any other shifter brand up there with those two.
Old Apr 17, 2018 | 11:41 PM
EVLGTO's Avatar
EVLGTO
I have a C6 shifter and couldn't be happier. I tried Hinson (waaaay to short and tight) and an MGW. C6 was enough for me. I dropped it in my stock C5 shift box, no issues here.
Old Apr 18, 2018 | 08:12 AM
Mickeyrx70's Avatar
Mickeyrx70
That’s the route I took, but I went with the C6 TPS 427 shifter. I DO plan on having the lower shifter box rebuilt like ~Josh and DetroitPlac mentioned above though.
To 2001 c5 6 speed shifter
