C5 drivers side wind noise
Old Apr 18, 2018 | 09:14 PM
chrisrazzzz's Avatar
chrisrazzzz
8th Gear
Default C5 drivers side wind noise
Anybody with a C5 coupe having trouble with wind noise on the left side window? Mine has wind noise and I don't dare take it thru a touchless car wash. The targa roof weatherstrip has been replaced and the dealer replaced something inside the door (at $525) but the problem persists. Dealer says all the weatherstriping is fine. Any help or suggestions will be appreciated.
Old Apr 18, 2018 | 10:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
there is a oblong plug in the bottom of the door, take it out and there is a adjustment nut for the window, tilt it in a little at a time !!! cured mine !!!
Old Apr 18, 2018 | 10:06 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
http://www.theredlion.us/TipIn.htm
Old Apr 19, 2018 | 05:43 AM
chrisrazzzz
8th Gear
Default Wind noise
Thanks, will try that!!!!! Got my fingers crossed.
Old Apr 19, 2018 | 07:07 AM
chrisrazzzz
8th Gear
Default wind noise
Should have asked..... how did you adjust this nut? And I have 2 oblong plugs. Do I adjust both or just one?
Old Apr 19, 2018 | 08:51 AM
The upper plug, behind the door pull, is there to secure the inner door panel to the door frame. It doesn’t do anything to adjust the door that I know of.
Old Apr 19, 2018 | 02:13 PM
chrisrazzzz
8th Gear
Much thanks for the directions!!!!!!!!!!!!!!!! Still got my fingers crossed. Will work on window
this weekend.
Old Apr 19, 2018 | 03:10 PM
Vanover's Avatar
Vanover
I knew I should’ve asked you about this. I’ve just been living with the wind noise.
Old Apr 20, 2018 | 07:35 AM
a_ahmed's Avatar
a_ahmed
hey those pix are broken on the link...
Old Apr 20, 2018 | 09:59 AM
Stephen Meredith's Avatar
Stephen Meredith
I wish the pictures worked
Old Apr 20, 2018 | 08:27 PM
Vanover's Avatar
Vanover
It’s very simple. There are three plugs on the bottom of the door. Two rectangular and one round one. The rectangle towards the back of the door and the round one is the ones you want. You will need a 3/16 socket with an extension and a flashlight to see the adjustment screws. Put the window all the way down and start adjusting. This will take a few times to get it rite. Roll the window up and close the door SLOWLY dont close it hard. I would hate for you to break your window. I just did mine. It easy as that. Good luck.
Old Apr 20, 2018 | 09:46 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I like to have the window up, can see how far you are moving it, a little at a time !!!!
Old Apr 20, 2018 | 09:51 PM
Vanover's Avatar
Vanover
I didn’t have an extension that long. Poor man he to use what he got.
Old Apr 21, 2018 | 02:26 AM
Stephen Meredith
Unfortunately, I have the infamous upper door hinge crack, so it sags when open and for it to close all the way I have to close it hard
Old Apr 21, 2018 | 12:32 PM
Vanover's Avatar
Vanover
Shut it as easy as possible. You just don’t want the window to be so far out of adjustment that it breaks when your when you close the door.
Old Apr 21, 2018 | 01:46 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
replacing the pins is not all that hard !!!!
Old Apr 21, 2018 | 04:13 PM
Vanover's Avatar
Vanover
How is OK treating you
To C5 drivers side wind noise
Old Apr 21, 2018 | 05:13 PM
Carl Timonen's Avatar
Carl Timonen
New pins won't help with a cracked door that's sagging. Only option I see is to remove the door and either replace the door or repair the crack. Then start over.
Old Apr 21, 2018 | 06:15 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Great !!! love the warmer weather and no snow, and Love my new life and Wife !!!!!!!!!!!!!
Old Apr 21, 2018 | 09:45 PM
rx4arx's Avatar
rx4arx
Hey, I have that article (or I assume it's the same one) as a hard copy. Been meaning to use it to see if it solves my problem...
Let me see of Ican scan it and figure out how to post it here for you...
