Gm top engine cleaner
Old Apr 24, 2018 | 09:48 PM
04zjimc's Avatar
04zjimc
Default Gm top engine cleaner
Has anyone used this stuff to clean the carbon off the piston's? Im looking to do this to my z..thanks
Old Apr 24, 2018 | 09:59 PM
StingrayRebel's Avatar
StingrayRebel
I've never used anything branded by gm but seafoam works great
Old Apr 24, 2018 | 10:27 PM
o2bnkc's Avatar
o2bnkc
Seafoam does work good!
Old Apr 25, 2018 | 04:09 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Sadly, GM discontinued the good top engine cleaner, when rats in California were getting cancer. The stuff they market now is a pale shadow of what it was.
Old Apr 25, 2018 | 04:20 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
My experience is that it doesn't work.
Had front knock sensor codes intermittently. Changed the knock sensor same thing.
Seafoamed properly on a running engine. Smoke show. Knock code gone for maybe a day.
Pulled cylinder heads. Carbon that it took a wire wheel to remove. The exhaust valves where coked with rock hard carbon.
If you have serious carbon, literally NOTHING will do the job of physically removing the heads and getting after it.
I could've soaked that carbon in any solvent imaginable for a week and it wouldn't have broken up. Stuff on the exhaust valve stems was like diamonds.
Old Apr 25, 2018 | 05:25 PM
04zjimc's Avatar
04zjimc
I thought it couldn't hurt to use this stuff..car runs fine and has 30,000 miles.They sell the gm stuff on ebay..not sure if its the original? Looks like seafoam is it..
Old Apr 25, 2018 | 10:37 PM
bikeriderga's Avatar
bikeriderga
I used it back in the day and was great.
Used to use it every 10K miles on my streetrods.
Old May 8, 2018 | 09:08 PM
04zjimc's Avatar
04zjimc
I just bought a bottle 32oz..i heard using seafoam thru the big hose on the brake booster is to big.. and not all cylinders get clean..
Old May 8, 2018 | 09:57 PM
StingrayRebel
that's why you use the port on the side of the intake behind the throttle body
Old May 8, 2018 | 10:21 PM
Jurgen1's Avatar
Jurgen1
I have used it and it works great .Best stuff out there . I use it on many cars that have low compression due to sticky rings and it works . Why are you trying to use it and what are you trying to do is the question ?
Old May 8, 2018 | 10:35 PM
04zjimc's Avatar
04zjimc
Im getting my car street tuned.. i have 31,000 miles and im the 2nd owner..car did alot of sitting. I figured it cant hurt. car has no problems. My friend used it in his c5 and it made a huge difference..same thing car sat alot..
Old May 9, 2018 | 01:50 AM
Yokesc5's Avatar
Yokesc5
Read somewhere GM suggested doing it every 30k miles. The master cylinder hose is what i used.
while in the airforce a mechanic from maintainence poured water down our poor ruuning chev truck, we ran it on 73 octane
To Gm top engine cleaner
