So here is a couple of visuals for you. I did this on my 1989 with the L98 engine, but you get the idea. I cleaned the engine, frame, radiator etc with no problems. The ole 89 popped immediately and I ran the engine till all the water was dry.
Mask and cover any exposed electrical. I sprayed on regular car wash soap, but the suggestions for Simple Green are spot on. I used a brush and towel to get in and around tight areas. I used hose to "trickle" water for a rinse and as mentioned NEVER blast your engine with high pressure.
I was super happy with the results. I did the same for my LS6 and it came out great.
I don't think there is anything cooler than when the hood of a C4 is propped up. Looks so dang cool with the tires and suspension exposed.
some of you should put a camera under the hood and drive thru a rain storm, Oh right some don't drive in the rain ??? I ask you with all the cars and trucks that drive thru rain why don't they have issues ????? (what do you think the fan does with rain entering the radiator ???):toe tap: (remember the engine is hot !!big key !!!)
1000? Right. Are the cars you get in really so filthy they all need steam cleaning? Really?
Think.
Pull the fuel rail covers on a car with just 7k miles since it was last cleaned. Would that be acceptable to sell? Or to repair if its getting engine surgery?
Do you think most C5s are cleaned every 7k miles or less??
Ha!
I cleaned and detailed my engine bay when I bought it 5 years ago. After 30K miles it's still clean and sure as hell doesn't need a steam clean. Maybe a light dusting.
1000, huh?
Of course not every engine compartment that gets power washed will have problems, but these cars are twenty years old and may not be so watertight anymore, so it does happen and the tow, troubleshoot and repair can be expensive. It's not worth the trouble.
I think one could be careful where you get water and be ok. I mean this thing is meant to keep hot oil and water inside of it. I would not soak it but these cars are designed to breath from the bottom even in the rain so......
On a side note, op your motor looks kinda clean to me
What's the best way to clean the key hole recessed into the drivers door? I'm afraid to spray it with the garden hose in case water gets in and ruins my door electrical components. I just don't trust that little flapper door that was developed decades ago. Another reason I won't drive it in the rain.
Ha!
So at your corvette shop, before ever opening up a motor, you steam clean the engine compartment to prevent contamination of internal engine parts? Makes perfect sense to me.
I have pressure washed my engine compartments on my vehicles at self serve wash bays forever and not had any problems. I will admit I am hesitant to do so with my vette and I drive it in only good conditions so it really stays very clean, but I think if it got dirty enough I would do it, being careful at how I aimed the wand.
Roughly 800 Corvettes pass through the shop in a year.
How many have you seen? One?
And you pressure washed every one of those? What I have seen is a friend took his C5 to the car wash, sprayed the engine bay and it would not start, had it trucked to the dealership to get it started at considerable expense. I have also seen countless threads here about how water has caused problems with these cars.
I am done here. You have not convinced me that it is smart to pressure wash a C5 engine bay. Not with what I have seen.
Not only cars we are going to sell or repair, but also cars we simply do small stuff to and wash as a courtesy, yes we pull the FRCs and wash down the engine bay. Never once heard of a single issue. I've worked here for several years both now and before.
I said it already earlier:
Originally Posted by ~Josh
Okay do what you want with yours. I'll see another 1000 blasted without problems.
I've seen literally hundreds of C5/C6 engines pressure washed with steam with no negative effects.
Basically, go to the car wash and do whatever the hell you want. Period.
Agreed. Cars and motorcycles are built to be driven and ridden in the rain. As such they have to account for moisture getting into the engine bay, unless you're in one of those new hermetically sealed Lexus hybrids :P
I have washed many engine bays with soap, simple green, etc. and a garden hose. The only time I got in trouble was when I used a power washer. I would avoid power washing.
I've never had a problem with any of my vehicles after using water on the engine...I just use care on what I direct the stream at. I avoid spraying directly on electrical connectors as pressure washers can force water into those, even those with seals...
We get so much dust/sand/salt-dust (this time of the year) from the roads in this area, every time I wash the car it gets a spray down in the engine compartment.
