MGW C5 Slap Stick Shifter Boot
Old Apr 30, 2018 | 08:00 PM
BarneyZ's Avatar
BarneyZ
Default MGW C5 Slap Stick Shifter Boot
How did you trim yours to fit? Please post a pic if you can!
Thanks!
Barney
Old Apr 30, 2018 | 08:09 PM
oneandgone's Avatar
oneandgone
I'm still confused why everyone thinks you have to do that. I just slid mine down over the shifter. Fits perfect.
Old Apr 30, 2018 | 10:02 PM
BarneyZ's Avatar
BarneyZ
Mine is too tight to slide down. No way. Yours looks good, though.
Old May 1, 2018 | 07:18 AM
brownrd's Avatar
brownrd
Thanks!
Barney
Using a very sharp (new) razor blade I trimmed away the top part of the boot that is folded over on itself, used the grommet provided by MGW, and a small tie strap to hold it in place.
Start the process by turning the boot inside out, then trim, fit and tie strap the grommet, and turn the boot back right side out for install. Make sure you get the grommet aligned correctly (long side aligned with long side of boot).
Sorry no pics with me, but if you have Instagram look for CanadianCorvette_c5 for photos.
The grommet makes the fit look perfect.
Old May 1, 2018 | 08:39 AM
BarneyZ's Avatar
BarneyZ
Thanks. That’s the way I thought it should go and you confirmed it. Now waiting on new boot and frame. Keeping the original because it’s perfect and will need it when I “part out” my mods in the future.
To MGW C5 Slap Stick Shifter Boot
