Headlights jiggly.
Old May 8, 2018 | 09:38 PM
1999corvettels1's Avatar
1999corvettels1
Default Headlights jiggly.
This is something I'm not sure if my car has done since getting in 2003, or as it's gotten older.
It's not constant, and I mainly notice it at night on freeways that are worn or rough, while approaching overpasses that have big street signs.
I will see bouncy or jiggly lights hitting the signs from a distance.
Is this common, or is something wrong?
I can't see the headlight's backsides (part that opens and closes) jiggle just the light projection on a object like a big sign.
Old May 8, 2018 | 09:40 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Mine do it too
Old May 8, 2018 | 09:50 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Not the jiggly headlights I was expecting...
Old May 8, 2018 | 10:28 PM
I think mine does it to some extent. Not surprising since they are pop up lights.
Old May 9, 2018 | 12:34 AM
Carl Timonen's Avatar
Carl Timonen
Do new headlight bump stops help?
Old May 9, 2018 | 09:09 AM
f6john's Avatar
f6john
My left side was “jiggley” when I got the car and upon investigation found the original bolt/pin that connects the lift arm to the assembly had been replaced and the fit was loose.
I suspect that if both lights are moving around some it could be that the plastic bushings that the lift arm pin goes through could be worn or brittle to the point they have fallen out.
I lucked out by finding a member in the classifieds parting out a headlight assembly that had just what I needed. Putting the correct pin and bushing back in place corrected my issue and the lights have been rock solid since.
Old May 9, 2018 | 09:58 AM
Velocity_Vette's Avatar
Velocity_Vette
My immediate guess would be to check the bump stops mentioned above. The bump stop rubber isolaters - you have four of them to each headlight, two that control the full open and close and two that "hold" it in place when open - deform with continuous use. As a temporary fix, you can remove each one and flip it 180 degrees so the "good" side contacts.
You'll see the two for the headlight door pretty easy. When you open your hood they're immediately on the "top" side of the headlight near the harness and motor ****. The two that control the full open and full close are a little harder to see. Raising the headlight motor manually via the ****, they will come into view on the headlight motor bracket. Obviously you can't raise the **** all the way otherwise you won't be able to actually remove the one that controls the full open position.
Other than those the only other items to check would be the physical mounts of the headlight assembly itself, which has a possibility of being loose, and also the nut that holds the pivot arm to the headlight body.
Old May 9, 2018 | 02:49 PM
jrprich's Avatar
jrprich
A common issue that is more visible when using HIDs with a sharp cutoff.......but it can be reduced.
https://www.corvetteforum.com/forums...id-jiggle.html
To Headlights jiggly.
