[Z06] Oil pan question...
Old Oct 18, 2002 | 02:15 PM
DIYdreamcar's Avatar
DIYdreamcar
Default Oil pan question...
OK, maybe I am just paranoid, but looking under my Z (which does require a little bit of doing to put it mildly) I noticed that the bottom edge of the drain port (where the plug screws in) in flat. Now since the bottom of the car is largely flat, I thought this might be OK, but since I am a little :crazy: I thought I would ask.
Is the bottom of everybody else's drain hole flat?!?!? (Please say yes)
Thanks in advance
-Ed
:cheers:
Old Oct 19, 2002 | 02:16 PM
nfshotrod's Avatar
nfshotrod
Default Re: Oil pan question... (DIYdreamcar)
They are supposed to be ground flat under the front drain plug. Your's is fine.
Old Oct 20, 2002 | 02:06 AM
DIYdreamcar
Default Re: Oil pan question... (nfshotrod)
Thanks, I thought I was being paranoid, but had to check....
-Ed :cheers:
To Oil pan question...
