Udders again
Old May 22, 2018 | 06:54 PM
bikemiser's Avatar
bikemiser
Default Udders again
How do I get to udders on passenger side. Take out battery?
Old May 22, 2018 | 07:08 PM
Ceedub53's Avatar
Ceedub53
See this discussion (and video) as it relates to your question:
https://www.corvetteforum.com/forums...our-vette.html
Old May 22, 2018 | 10:10 PM
Mickeyrx70's Avatar
Mickeyrx70
Taking out the battery is one option, but I prefer to remove the wheel then remove the access panel in the back of the wheel well. That exposes the bottom of the single udder on that side. I’ve not had to actually remove the udder itself to clean it but “milk” it instead to remove any debris.
Old May 22, 2018 | 10:16 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I will have the wheel off soon to replace the sway bars....so that access panel how big is it and is it just held on by sheet metal screws?
Old May 22, 2018 | 11:02 PM
Mickeyrx70's Avatar
Mickeyrx70
Yes it’s held on by a few screws. The panel isn’t large. It also gives you access to the pcm some people send off for the mail order tunes you hear about.
Old May 22, 2018 | 11:05 PM
Taking the access panel off is pretty easy, but there is one screw that is kind of hidden - it is on the underside at the rear of the panel. You'll see it if you just follow the panel lines.
Old May 23, 2018 | 09:48 AM
bobs77vet's Avatar
bobs77vet
thks bob
Old May 23, 2018 | 01:23 PM
knewblewkorvette's Avatar
knewblewkorvette
I found taking out the battery is the easiest way to get to that one udder.
Old May 23, 2018 | 03:54 PM
Ceedub53's Avatar
Ceedub53
Old May 23, 2018 | 10:53 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
So this thread gave me inspiration to clean out the udders. The drivers side (all three)took about one minute- serious. I ws lucky as they were not clogged.
I took the battery out and followed the udder as it snaked down around the wheel well. Again I was lucky as the udder was squeaky clean.
The who process took less than 15 minutes. I'm thinking pretty good PM and a super quick reward for the effort.
Old May 24, 2018 | 08:06 AM
awches's Avatar
awches
All of mine were full of leaves and trash on my 03. Did pull the battery for the passengers side.
Old Jun 1, 2018 | 10:37 AM
bobs77vet's Avatar
bobs77vet
well i found two of the three on the drivers side, i am thinking the plastic udder is missing on the third...need to study some photos to see where it should be. they were complete clean and empty, the car has been garaged mostly so i am not surprised , it was hard to reach up and see it there was a hole for the third one ...time to go look at some photos.
edit: time to go back down to find the third one
Old Jun 1, 2018 | 10:54 AM
bobs77vet's Avatar
bobs77vet
ok found the third one hiding in the back..it has a slight amount of crusty remnants in it, not much but enough to clean out. now to do the 4th one this weekend. if the car is up on jacks can you reach up and get it or is there something blocking straight access up to it.
with the elite rocker rail bars and a low frame jack i can get the car up in the air on both sides in about 6 minutes total time.
Old Jun 2, 2018 | 02:55 PM
johnson-rod's Avatar
johnson-rod
Yes.
Old Jun 3, 2018 | 11:14 AM
bobs77vet's Avatar
bobs77vet
excellent thanks
Old Jun 3, 2018 | 12:10 PM
GCG's Avatar
GCG
Pictures of the 3 udders in the driver's side and the 1 in the passenger's side:
Old Jul 1, 2018 | 08:35 PM
bobs77vet's Avatar
bobs77vet
success, when I had the car up in the air to replace the sway bars I took the access panel off, it was very simple and yes that one lower screw to the fender was hiding on me....I was surprised to see the udder opening all the way down at the bottom of the fender, I guess I was thinking it was going to be up higher like the others. thanks bob
To Udders again
Old Jul 2, 2018 | 08:44 AM
grampi50's Avatar
grampi50
What is the purpose of the udders (other than to collect crap and get plugged up)?
Old Jul 2, 2018 | 11:35 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Quick question- I put the passenger udder back on and routed it back down by feel rather than by sight. There are no kinks or anything but I want to make sure it's routed properly so that it's not dropping water onto anything sensitive (such as wires/electronics). Is the routing of the passenger udder pretty foolproof to put back on? I don't feel like going through the hassle of jacking/lifting the car up to look underneath.
Old Jul 2, 2018 | 12:04 PM
bobs77vet's Avatar
bobs77vet
well i will offer this assessment from the bottom up perspective.....there is not much open real estate down there so if it went in easily and you didnt feel it binding i bet you are ok. i dont see how you could make it fit wrong with our feeling the binding or kinking of it. if its in properly the udder split opening is lower then the control modules that also are in that general space.
you just have to jack it up high enough to turn the wheel so you can access the screws, the wheel doesnt have to come off
