Fuel Pump Heat Shield
Old May 24, 2018 | 05:43 AM
jeffwest5599's Avatar
jeffwest5599
Default Fuel Pump Heat Shield
Is there a heat shield that goes over the fuel pump on the left and right side. I know there is one under the tank but is there also one that goes vertical over the fuel pump area. I see where the unit goes in the tank and I thought there was supposed to be a heat shield there.
Old May 24, 2018 | 07:52 AM
StingrayRebel's Avatar
StingrayRebel
the tanks are wedged up in between the frame and that heatshield you are referring to is also what holds them in the car from the bottom... there is a small piece that goes around the side and covers the fuel hat if that's what you are referring to, not my pic but this is what it looks like
Old May 24, 2018 | 09:58 AM
cadwiz_01Z's Avatar
cadwiz_01Z
Veteran: Marine Corps
From: When Democracy becomes tyranny, the armed citizens will still get to vote!
I've got a set. Send me a p.m. if you need/want them.
To Fuel Pump Heat Shield
