Front Air Dam Question
Old Jun 5, 2018 | 07:46 PM
StocktonC7GS's Avatar
StocktonC7GS
Default Front Air Dam Question
Has anyone used these to replace their front air dam? Looks like a decent product but looking for opinions on this product or if anyone has used anything else.
https://www.rpidesigns.com/shop/item.aspx?itemid=1905
They offer a corner reinforcement kit to go along with it.
https://www.rpidesigns.com/shop/item.aspx?itemid=1908
Old Jun 5, 2018 | 08:17 PM
calguy's Avatar
calguy
The only thing I can speak about is the corner reinforcement pieces, and the fact they aren't necessary.
You can remove the screws holding the corner pieces on, and put a 1" washer, with a small hole to fit the screw, and re-attach them.
That is plenty of reinforcement.
I did that, and it has worked out fine.
Bob.
Old Jun 5, 2018 | 08:30 PM
I have those reinforcements on my air dam corner pieces and they do work well.
It might be worth a try using the washers mentioned above and see how you like them.
To Front Air Dam Question
