C5 Codes
Old Jun 9, 2018 | 06:25 PM
gellisvette's Avatar
gellisvette
Default C5 Codes
Is there someplace to decipher codes from a 1999 c5???
Old Jun 9, 2018 | 11:44 PM
Tuffguy610's Avatar
Tuffguy610
Very easy to do!
https://www.corvetteactioncenter.com...-codes-c5.html
Old Jun 10, 2018 | 12:51 AM
Are you talking about the diagnostic trouble codes or the RPO codes which show the options on the car?
Old Jun 10, 2018 | 06:19 AM
SG Lou's Avatar
SG Lou
Diagnostic codes here :
http://www.stengel.net/diccodes.htm
RPO Codes here :
https://www.corvetteactioncenter.com...99/99rpos.html
Old Jun 10, 2018 | 10:58 AM
gellisvette
Default codes
Originally Posted by SG Lou
Thank you very much, extremely helpful. Thanks again Geo.
Old Nov 30, 2020 | 04:40 PM
tom bulat's Avatar
tom bulat
Cruising
Default C5 codes
These prompts don’t delete “maximum speed 80 miles “and “inoperative suspension “Is anyone who knows how to delete these two ? Thanks tom
Old Nov 30, 2020 | 06:13 PM
SilverC54me's Avatar
SilverC54me
You need a Tech2 to remove the option for F45/F55 from the BCM.
If you are in SoCal, I can do this for you.
Gary
Old Nov 30, 2020 | 06:55 PM
tom bulat's Avatar
tom bulat
Cruising
Default C4
Thanks Gary!!! how can we do that and how much would you charge ?
Old Nov 30, 2020 | 07:36 PM
SilverC54me
Well I am in California, From what I can tell you are in South Carolina. I would suggest posting in the regional section a help wanted to remove the F45/F55 option from your car.
Here are the steps to follow once you find a person with a Tech2:
1. Hook up Tech 2, turn car on, make sure module in the rear is plugged in. Do not unplug the rear module.
2. Use Tech 2 to delete the F45 option (F55 does not appear on the menu screen, use F45).
3. Save new configuration.
4. Do not turn car off, do not remove Tech 2. Go to the module in the rear of the car, unplug the grey connector (the widest one), leave any other plug(s) in. [leave the other 1 (F45) or 2 (F55) plugged in]
5. Turn off car, leave Tech 2 plugged in.
6. Remove remaining plugs from module in the rear of car. [never plug them back in again, if you do the F45 turns on automatically] (Recommend removing the module)
7. Turn car on to verify the "max speed 80 mph" is gone.
8. Unplug Tech 2.
Gary
Old Nov 30, 2020 | 07:51 PM
Smoken1's Avatar
Smoken1
I gave you a link to buy your own Tech2 in your post in the tech section
To C5 Codes
