am i missing a bracket/bar for my lower dash???
Old Jun 12, 2018 | 09:09 AM
2k2wranglerx's Avatar
2k2wranglerx
C5 of Year Finalist (performance mods) 2019
Default am i missing a bracket/bar for my lower dash???
So my lower dash (under my steering wheel) was held on with a screw through the side... which obviously isn't correct. When i look at pictures and instructions (like to do the lingenfelter clutch spring) they show 2 screws on the under side of the dash pad...
i don't have a bar or anything that runs here... am i missing something? Why someone would remove it i have no idea. But what should be here? right now i only have the upper fasteners in the lower dash cover holding it on.
i'll take better pics tonight. But any idea what piece i'm missing? I'm sure once i figure it out i can hit up someone parting a C5 out.
People do the weirdest stuff to these cars lol. why would someone remove that...
Old Jun 12, 2018 | 09:16 AM
2k2wranglerx
i'm going to look when i get home. but i swear i'm missing that silver bar there. (pic taken from lingenfelter instructions)
Old Jun 12, 2018 | 09:41 AM
Lilbluevette's Avatar
Lilbluevette
I think the metal support is in upside down. ???? If I remember right.
Old Jun 12, 2018 | 09:42 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if you can figure it out I may have it...let me look at my parts....
Old Jun 12, 2018 | 09:45 AM
2k2wranglerx
i'm not following? are you looking at the pic of my car and seeing something on wrong?
That would be awesome. I can't find a pic showing that support area online. I'll snap better pics tonight when i get home of what's there... and what's not lol. I'm happy to buy it if you have it.
anyone have any pics of that lower dash area. specifically that bar/area the lower dash bolts to?
Old Jun 12, 2018 | 09:48 AM
Lilbluevette
Not sure, I may have spoke too soon. I'll look at mine when i get home and let you know. If you haven't figured it out by then.
Old Jun 12, 2018 | 09:52 AM
2k2wranglerx
i appreciate the help!
Old Jun 12, 2018 | 11:01 AM
2k2wranglerx
Dude you may be right! Here's mine
here's one i found on the web
that piece certainly looks different
Old Jun 12, 2018 | 05:14 PM
Velocity_Vette's Avatar
Velocity_Vette
I think what was said above about the metal support piece being upside down is correct. The lower column "kick panel" bolts towards the bottom by the pedals and slips into the trim area above it near the wheel (if memory serves me right there are actually a bolt or two up top, including one that's hidden in the interior temp square vent).
As to why that may be flipped, back in the day prior to the LMC5 most CLBs were installed directly under the column (these are often referred to as Corvettes of Houston CLBs, since they were the big vendor to supply them). To install them, most removed the under column kick panel to easily access everything. You **could** install it all with the panels in place but it's a real PITA to do it that way. There's a chance that whomever was trying to install an old CLB just started removing stuff and didn't re-install everything correctly.
Old Jun 12, 2018 | 06:24 PM
SilverC54me's Avatar
SilverC54me
I agree, the support structure is installed upside down. On the ends of it were the screws for the knee bolster go, there should be the spring clip style captive nuts. These just slip over the end.
To am i missing a bracket/bar for my lower dash???
