Super sticky air bag
with what's already been suggested:
. However, be aware that the color will be removed along with the sticky film, leaving the airbag cover just black. I read that someone had good results applying one of those spray dyes for rubber/vinyl afterwards. Not sure if it was SEM, but it was a perfect match. Let us know how it goes Last edited by GCG; Jun 16, 2018 at 02:57 AM.
with what's already been suggested: Goof Off water-based formula. However, be aware that the color will be removed along with the sticky film, leaving the airbag cover just black. I read that someone had good results applying one of those spray dyes for rubber/vinyl afterwards. Not sure if it was SEM, but it was a perfect match. Let us know how it goes
Might want to clean it up which would remove the color, then take it to an auto restore shop, like the ones that drive around car dealerships restoring used cars interiors. They may be able to blend a dye for you.
You should be able to find them on google search.
I used tuff stuff on mine which turned the airbag whitish but no longer sticky, then taped up everything and sprayed it with black SEM black dye. Looks perfect.
Stock #: C9228J
Code: 9648
Color: Medium Dark Neutral
Now I understand why someone wrote it takes about an hour. Multiple soaking and rubbing with micro.
Looks great and no more sticky feel!
http://www.axaltacs.com/corporate/en...Locations.html
Their Global headquarters is just a few blocks away from me here in Philadelphia, I can stop by for you guys haha.
There are numerous threads on here about this problem and many solutions have been offered to get the sticky off.
My 2000 A4 just developed this - it has been cold down here, car is always under the house out of the weather and sun, never used Armorall or anything on it, it just decided to get real sticky. It has to do with "outgassing" of the vinyl and is a natural part of the aging process of this material.
Suggestions to clean it off have included a degreaser, Goo Gone, Goof Off, lacquer thinner, saddle soap, scrub with a Scotchbrite pad, and others I have forgotten. I used what I had around the house -
I tried first with Pine Sol (degreaser), which worked somewhat but not entirely, alcohol (did nothing), mineral spirits (slightly effective), and because none of these harmed the surface, then went to a rmicrofiber towel with a little acetone on it, That did the trick and did not harm the surface at all, just cleaned it off to new, Sounds drastic, but it worked and did no harm, and was quick and easy.
Then, to protect it, I sprayed it and wiped it down with Silicone spray, and now it looks like new and feels great, smooth, clean, and not too shiny. It's been like that a few weeks now. - very happy with the result. I may spray it and wipe it down every few months, if I remember.
My end result looks just like gowenfast's pic up above.
Bill
