Rear Tie Rod
Old Jun 20, 2018 | 12:48 PM
BRKLYN's Avatar
BRKLYN
Default Rear Tie Rod
Having a hard time finding Tie Rod End rear, from the auto parts store. Calling Reedman-Toll Brothers Chevrolet.
Old Jun 20, 2018 | 01:31 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Are you referring to Rear Outer 88955488?
If so, they are available through multiple sources. There are several vendors on the forum that could help you with new ones including Cultrag, SDPC, GMPartsDirect, Willcox Corvette and many others whom I am sure will add their names to this small list. If you prefer good used ones, try Vettenuts.
Best wishes with your efforts to find your parts.
Old Jun 20, 2018 | 01:47 PM
JR-01's Avatar
JR-01
If you want to shop around for best price, Amazon and Rock Auto have them.
Old Jun 20, 2018 | 04:23 PM
There shouldn't be that much of a problem finding the parts. Call some of the vendors that Route99 listed, Your dealer should have access to it also, but probably at a higher price.
Old Jun 21, 2018 | 09:04 AM
BRKLYN's Avatar
BRKLYN
Auto parts stores came up short. Had to cancel my alignment today. The stealer wanted $147.00 for it, it was a day away. Found it on R-A for a fraction of the $$$’s. Thank you all for chiming in.
Old Jun 21, 2018 | 02:16 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
I had a hell of a time finding this part as well. IF you're referring to the rear outer tie rod, you can just press out the ball joint. In my case it was the lower ball joint, which should be the same part number as the front lower. In any case, I ordered a set of Mevotech ball joints from Rock auto, if that helps you any.
Old Jun 24, 2018 | 05:34 PM
BRKLYN's Avatar
BRKLYN
Tie Rods came in but, they're the same length as the fronts. In the rear, are the called something else? Just bought new tires need to get aligned.
Old Jun 24, 2018 | 05:36 PM
BRKLYN's Avatar
BRKLYN
Default Bump
P/n GM 88876789
Auto Zone p/n and installed one for the front ES2231R
Old Jun 25, 2018 | 06:34 PM
SG Lou's Avatar
SG Lou
I have a pair of Ecklers and do believe they are the rear tie rod. Reason I say that is I bought them as they stated they were for the front. Had a shop put them on Grease them up and do the alignment and then they couldn't set the toe adjustment because the new tie rod ends were way too long. That's what makes me believe that Ecklers sent me rear tie rods as opposed to front. I had the shop remove them put the old ones back on and I waited on a alignment until I got a new pair of tie rods just for the front. Like I says they were installed greased and then removed. If you can measure the length of the front tie rod and give me that measurement I will measure the ones I have and see if they're longer. I did read someplace that the rear tie rod ends on a C5 or about three quarters of an inch longer than the front tie rods. Let me know
Old Jun 26, 2018 | 10:12 PM
BRKLYN's Avatar
BRKLYN
Yes, Three fourth of an inch longer. I have to return these to R/A. I will measure end to end tomorrow. I will be installing torsion bar links, I did the rears today. Stealer wanted $127.00 for rear tie rod.
To Rear Tie Rod
