i just finished installing led headlight and fog light bulbs and when i went to turn oin my headflights, everything was dead, including the ignition start. I have a 2004 c5 corvette and i'm thoughly annoyed as to this situation. When turn the ignition key to start the car i'm getting zip, no sound no nothing. Can somone out there dirtect me as to what to look for or how to resolve this matter. Greatly appreciate your insight and assistance.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well start with making sure the battery is fully charged do you have a volt meter to test it with ? google battery voltage charts it will show you what a battery should read.
also check your battery connections and make sure they are tight.
how long did the car go for undriven while you did your work?
tHANKS; i'M GOING TO PUT IT ON THE BATTERY CHARGER, BECAUSE I THINK THERE IS A SHORT IN THE ENGINE COMPARTMENT LIGHT WHICH THE MORONS AT THE CHEVY DEALERSHIP WERE SUPOSE TO FIX; THANKS FOR YOUR INSIGHT, I WILL LET YOU KNOW IF THAT IS THE PROBLEM.
its not unusual for the batteries in these cars to go dead after 10 days+ of not using them....some cars its longer some cars its shorter, a lot of us use trickle chargers to keep the battery charged when we are not using it.
As mentioned, I also suggest checking the battery first. If it continues to happen you may need to install a hyper flash relay underneath the steering wheel. I swapped out my entire exterior lighting to HID/LED and had to install the hyper flash relay because the LEDs draw so much less energy than the stock halogen, that the system thinks a bulb is out. In your case, the system may be continuously draining from the LED swap.
thank you bob for your help, i hunged up my battery charger and a little while later, it kicked right over without hestiation; thanks again for your advise, i do appreciate your kindness;
